Front Spindle\Knuckle '73 F100
I have a '73 F100 4x2. When trying to remove the caliper, the bolt broke. I tied to use a bolt extractor, but it also broke inside the bolt. This entire project became a major mess. Trying to remove the bolt, I don't think is an option any longer.
I think, I now have to replace the entire Spindle\Knuckle.
My 1st question, by looking at my pic, is there another option, other than changing the spindle\knuckle (or does it look too damaged) ?
2nd question, I can't find a spindle\knuckle anywhere. Any recommendations where I can get one.
3rd question, how hard is it to replace the spindle\knuckle ?
Thank you for your help
Thank you Hotrod_Merc , I was able to get the knuckle off. I'll have to take it to a machine shop to see if they can fix it. it looks worse than what the picture shows.
I have one other question. The King Pin came out fairly easy. Would there be any reason to change the bushing, ? I'm not sure what to look for, but i do see a couple of minor nics, but seems to be ok. I assume to assemble it back is use some chassis grease, to place the King Pin back in ?
XzXPatrickXzX
09-17-2009 09:38 PM
Supercab
02-19-2003 09:54 AM
