Sad that you have to check this since a mechanic installed the brakes but while you have the drums off measure the length of brake material on the shoes.. believe it or not the leading shoe should have slightly less material than the trailing shoe, and if the mechanic somehow put both trailing shoes on one side that wheel will be very lockup prone.
just pulled the hubs and the trailing shoe pad thickness is bigger than the leading shoes on both sides. The actual pad length on all four shoes are the same. Approx 11 1/8". Any clue from the pic? Leading shoe is to the right.
The brake dust wiped off on the cylinder is on the passenger side. The driver side had almost none on it. They were replaced about 500 miles ago.
Pic is too dark to see the extent of the friction surface on the leading shoe. You might be able to boost the brightness of the pic, or just re-shoot it and compensate for the uneven light pouring in from frame left. It does look, however, like the leading shoe has a smaller friction surface.
If the friction surface is the same length on all four shoes, then the set was mis-packaged; either you got all trailing shoes or all leading shoes.
Sorry about the pic. I used a caliper to measure and the pad thickness and they are different on both leading shoes and trailing shoes. The pad lengths are all the same on all four. I didn't buy the shoes but they most likely came from O'rileys.
Wow that would be unusual but certainly a possibility. The pads are all the same length on mine. From the earlier post from Paul (which I appreciate) I couldn't tell if he was referring to pad thickness or pad length or both. So madpogue, you are saying the pad surface length of the leading and trailing shoe should not be the same? If so like I said mine are all the same length. Anyone have any conflicting info on these shoes before I visit Big O.
I may be wrong but I think if you take the shoes off and place one on top of the other, you will see that one pad is longer than the other. I looked at the lengths of the pad when I replace my brake shoes.
i have seen them different sizes, and also seen them the same size. i think it has something to do with where the material is placed on th metal brake shoe itself.
The linings are designed to be the same thickness, but different lengths. Depending on the design, the bigger lining goes to the rear, because of the "self-energizing" action of drum brakes under a braking condition. The shoes expand out, then the primary shoe (the front-small one) is wedged down into the drum because of drum rotation. This is the self energizing action. The secondary (the rear-larger one) shoe is wedged up into the drum because of drum rotation.
Since the primary show wedges down, the top of the shoe is of less importance to braking and therefore there is less pad at the top of the primary shoe. The secondary shoe wedges up, so the bottom of the pad is less important, except for when the parking brake is applied. This is why the secondary shoe has more material, it uses the whole pad under different conditions, where the primary one does not.
Thanks Glenn
After I read your post I measured the entire length of the shoes from metal end to end. All four are 15 1/2". I remeasured the pads from end to end. Shoes are the same length and the pads are the same length 10 1/8" . So if you had one pad longer than the other I must have a mixed up set especially since the pad thicknesses are different on mine. Sandy
When my friend got these he may have given O'riley the wrong year or they may have given him the wrong year. ?????
just pulled the hubs and the trailing shoe pad thickness is bigger than the leading shoes on both sides. The actual pad length on all four shoes are the same. Approx 11 1/8". Any clue from the pic? Leading shoe is to the right. The brake dust wiped off on the cylinder is on the passenger side. The driver side had almost none on it. They were replaced about 500 miles ago.
If that's the passenger side brake drum, that is assembled correct. See how the forward or primary shoe has a shorter lining than the rear shoe?
When braking, the forward shoe tends to continue on in the direction of rotation (down); and away from the anchor pin, secured by a spring.
The primary shoe in turn, is directly connected to the trailing shoe through the adjuster link. This rotation forces the trailing shoe up, on the direction of rotation, but it's always tight against the anchor pin when moving or braking in the forward direction, so it has has nowhere else to go and wedges itself out, against the drum, providing greater braking action and stopping power than would otherwise be the case. This is the "servo" or bendix self-energizing design. When adjusted properly and serviceable it works pretty well. The springs and everything needs to have good quick return action when the pedal is let off. A bad hose, weak springs or gouged shoe pads will interfere
with this.
The trailing shoe is normally thicker, and was oftentimes a slightly different lining composition.
I understand now how they work. Thanks for that. So are you saying that since my brake pads are all being the same length they are the wrong ones? It sounds like it from the way they work. Thanks Sandy
So the trailing (secondary) shoe is both slightly longer and thicker than the leading. You might want to measure the lining length again, there might be that slight difference.
Now the weird part is, look at the pics of some of the sets available for the F150s on RockAuto. Some show a BIG difference in the lining length, one (Monroe) shows the linings "offset" differently between leading and trailing. Fah, who knows, there may have been some aftermarket/engineering changes over the years. Any idea what brand shoes these are?
I just measured my secondary linings and primary linings and they all four are the same length 11 1/8". I assume your info above at 10.46-62 is inches. If so, it appears my linings are to long creating to much friction surface causing my rear brakes to lock up easily?
After searching there is a lot of confusion about this. I got a new set of shoes today and the linings, for all purposes, are the same length. The position of the linings are in different places on the shoes. It makes sense that the primary shoe would have more of the lining on the bottom area than the secondary shoe based on the info above.
If this is the case, the leading shoe would be on the right side in this picture. Is this correct?
Would a picture of my brakes help you out? I took a lot of pics before and after I replaced them. Mine worked good before and after I replaced them. Except I left the parking brake on and drove about 10 miles.
A picture of your shoes installed where the linings show on either top or bottom would be great. If you can have a picture of the liners on top or bottom see if my picture is correct.
