1998 F250 4X4 4.6L 136,0000 miles
Old 02-26-2011, 06:01 PM
joesmealsonwheels
joesmealsonwheels is offline
joesmealsonwheels is starting off with a positive reputation.
As anyone ran into the probelm of the rear drum brakes locking? I changed the brake shoes, the springs, the wheel cylinders(one side was not retracting) and then lastly the drums. I still get the locking. If I just put the drums on both sides, It does not lock. When I mount the tire and don't tighten the screws the tire spins fine. However, when I tighten the lugs, the brakes lock. I adjusted the brake shoes to the drum, bled the brakes and I still have the locking. Can someone help me on this.. Thanks..
Old 02-27-2011, 07:30 AM
Lazy K
Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Have I got this straight? Your rear brakes were dragging so you lifted the tires clear of the ground and replaced both wheel cylinders, brake shoes, hardware and drums. When you fitted the drums, both would rotate normally. When you fitted the wheels, both would rotate normally. When you tightened the lugs and before dropping the rear to the ground, neither wheel would rotate and both were locked.
Is that correct?
Old 02-27-2011, 07:35 AM
atccracing
atccracing is offline
atccracing is starting off with a positive reputation.
Aftermarket wheels?
Old 02-27-2011, 01:55 PM
joesmealsonwheels
Yes, that was correct. I found out what the problem was - the autopart store sold me the 3" pads instead of the 2 1/2" pads... This solved the problem.. Thanks for response...
84FordTruck
01-09-2014 12:08 AM
Roger Carter
02-22-2012 06:38 AM
RabidJade
Ranger & B-Series
11-06-2005 07:48 AM
graymule
15
01-23-2005 08:05 AM
perryphilip
07-16-2003 09:38 PM
Quick Reply: 1998 F250 4X4 4.6L 136,0000 miles
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
