Brake problems
Old Sep 25, 2003 | 01:53 PM
MustangGT221's Avatar
MustangGT221
Brake problems
I changed my rear drums about 3 months ago. I didn't have trouble getting the drivers side off (as it had already been taken off before that) and the passanger side I had to move the star wheel. At first, the truck felt like the brakes were dragging. That feeling kind of went away and they felt....ok but not great. I put the 35s (instead of the old 32s) on, and i noticed more predominately that the passanger side rear tire locks up very easily. The brake petal feels very firm and spongy (but the brakes have been bled), and it feels like the rear brakes are getting more stopping power than the front. I can go in reverse and hit the brakes and it isn't very easy to lock up the front tires (used to be pretty easy). I'm not very familiar with brakes, but I did put new front pads in. The rear shoes were ok so I left them. My dad messed around with the star wheels to take the old drum off and the new one on, but I'm not sure how that all works. What should I do?
Old Sep 25, 2003 | 02:04 PM
stepman's Avatar
stepman
The star is what adjusts the shoes to the correct position. Lift the rear wheels off the ground and spin the wheels. Turn the star until you cannot spin the wheel any more. ( don't make it too tight, just enough to where yu can't spin it)
Back the star off now( turn in opposite direction) usually about 12 "clicks until the shoes no longer drag on the drums.
If you find yourself turning a long ways and the wheels don't stop, you may be going the wrong way.
You may also need to use a screwdriver to push the adjuster out of the way to turn the star.( when backing off)
Sounds like you have 1 tighter than the other.
Old Oct 2, 2003 | 11:52 PM
RIGBOSS's Avatar
RIGBOSS
WHAT AND WHERE IS THE STAR?>??
Old Oct 3, 2003 | 04:57 AM
stepman's Avatar
stepman
The "stars" are a screw with a bunch of teeth on em. They are inside the bottom of the drums holding the shoes apart. They can be accessed through a hole in the bottom of the backing. Laying under truck facing wheel, there is a small slot under the axle. You can reach in there with a screwdriver and turn the star. (will go up and down)
Old Oct 3, 2003 | 12:08 PM
90f150moneypit's Avatar
90f150moneypit
As a side note; the star wheel is a self (automatic) adjuster. You need to set it as stepman said so that the brakes aren't too tight to start with. Then roll the tire backwards and hit the brake, do this several times.
I usually chalk the front tires and lift the rear axle off the ground and start the motor. I let it idle in reverse to get the tires spinning and hit the brake pedal with my hand several times to get the brakes adjusted. This is much easier than driving it in reverse and hittting the brakes.
Old Oct 3, 2003 | 03:22 PM
stepman's Avatar
stepman
I agree with that moneypit however, I never have any luck doing it that way. I have to move the veh back and forth about 10' so that the shoes will shift or it doesn't seem to grab the next notch. That might be just me though.
Something to think about...When I change shoes, I'll set them close then drive about 5 miles to wear them in a little and then make a final adjustment. Itmakes a big difference.
Old Oct 3, 2003 | 11:58 PM
c96drumm's Avatar
c96drumm
Mustang, why did you change the drums? Were you having any of this trouble before that?
Old Oct 4, 2003 | 08:21 AM
MustangGT221
Well, they are not very expensive, and the truck has about 100k mi on them, and one of my buddies at my uncle's shop said they should probably be replaced. I figured that since I have 35" tires that I should keep my brakes in tip top shape.
Old Oct 4, 2003 | 09:57 AM
c96drumm's Avatar
c96drumm
That'll teach ya to fix things that aren't broke!
I would guess you need to adjust 'em as described above. Good luck! Let us know how it works out.
Old Oct 4, 2003 | 10:18 AM
stevieray's Avatar
stevieray
When you installed the new drums did you wash them down with brake cleaner first? They are coated to protect them from rusting while in storage. Also, I have found that chamfering the leading (and trailing) edges of the brake shoes eliminates the typical Ford brake lock-up when cold syndrome. I did this when I installed new shoes 4 years ago and haven't had a problem since.
Old Oct 4, 2003 | 05:58 PM
MustangGT221
They do it all the time not when just cold.
Old Oct 4, 2003 | 10:39 PM
stevieray's Avatar
stevieray
The brake biasing valve may need to be centered. Sorry I cannot remember how to do this but I am sure someone out there does or check Haynes on -line.
Old Oct 4, 2003 | 11:28 PM
c96drumm's Avatar
c96drumm
If it has that valve(my 89 E-150 doesn't), I think it centers itself when you apply the brakes.
Could this be a RABS problem?
Old Oct 5, 2003 | 08:31 AM
MustangGT221
I'm pretty sure it's just an adjustment in the brakes.
Old Oct 7, 2003 | 10:41 AM
gatesj's Avatar
gatesj
Are you sure there's no air in the front brake circuit!?!?
