Sponsored by: Real Truck
Running cooler
Old Apr 23, 2017 | 01:39 PM
dubnasty216's Avatar
dubnasty216
Running cooler
installed a smoke switch in my 03 6.0L not to make smoke but to be able to turn the "whistle" off when I'm idling and working around the truck. But I've noticed that during the day when it is 85-90 degrees out, the egt will run about 60 degrees cooler with the turbo off. Is this good, bad, or indifferent for the truck?
Old Apr 23, 2017 | 06:36 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
'What' is running 60* cooler? ECT, EOT, IAT?
Old Apr 23, 2017 | 09:15 PM
dubnasty216
The EGT reading from my gauge
Edited my original, sorry for the confusion
Old Apr 25, 2017 | 10:59 AM
texastech_diesel
Token Redneck
No worries. How'd you install the switch? I'd be indifferent, it probably has something to do with the interplay of opening up the VGT vanes with roughly the same amount of air being pumped in the front. If you really don't use it as a smoke switch and only open up the turbo for short periods when you're idling I don't see it causing an issue.
vtown00
Jan 15, 2014 06:03 PM
HEAVY-DUTY
29
Sep 2, 2013 10:25 PM
Kdr358
Dec 31, 2012 07:04 PM
copracr
May 23, 2012 05:40 PM
BobDG
Aug 20, 2009 10:25 PM
