Weird jerking symptom
Old Apr 22, 2017 | 07:47 PM
Chris Hart's Avatar
Chris Hart
Me and the wife just now noticed this issue after about a week of owning this 6.0 f350 auto 4x4. Leaf spring front and rear. Long bed. Listing all this stuff because not sure if it matters.
Around 50mph if we drive normally about 1500rpm the truck seems to jerk a little as we climb in speed. If we get the truck into the 2000rpm range it goes away.
Not sure if it's suspension, transmission or engine.
Anyone have a clue what it could be. ???
Old Apr 22, 2017 | 11:22 PM
bismic's Avatar
bismic
What year model is it?
If it is a 2004. then where is the ICP valve located?
Get the codes read.
Make sure fluids and filters are fresh (in spec) and batteries are charged.
Old Apr 23, 2017 | 06:58 AM
Chris Hart's Avatar
Chris Hart
It's a 2003. I think it's possible a sticky injector after reading some threads. But if it was I figured it would be doing it at all speeds and at idle also
Old Apr 23, 2017 | 07:03 AM
mustang_309's Avatar
mustang_309
Each time I've had this happen I've ended up having an injector fail, it always happens on the low end of a gear with light throttle. I would imagine other things can cause it also but this has been my experience.
Old Apr 23, 2017 | 07:11 AM
bismic's Avatar
bismic
Do you have a scan tool that can read live engine data? If you do, watch your high pressure oil pressure and IPR duty cycle value.
http://www.powerstroke.org/forum/att...iagnostics.pdf
Old Apr 27, 2017 | 09:43 PM
Restlesswildman's Avatar
Restlesswildman
All the times it happens on my 03' Ex it is an injector. The problem is it hardly ever sets an injector code. I always get a p0603 code and nothing else. Only once did I get a contribution code or a high/Low voltage code for the injector.
A sticking turbo will give the same symptoms. You usually get a p132 code with an over boost code though.
Old Apr 28, 2017 | 01:16 AM
Euroman's Avatar
Euroman
Blue spring mod? I had this sort of uncertainty when accelerating at those sorts of speeds, higher revs not affected. Only thing that really cured it was the blue spring...
frdf250
May 24, 2016 07:40 AM
92mnfordtrk
Jun 9, 2014 08:50 PM
alexisvfd
Sep 26, 2011 06:33 PM
His/Hers 6.0s
Feb 19, 2010 07:38 PM
AK1MKING
Jun 9, 2004 12:08 PM
