2007 E150, what is causing it do die while driving?
Old Apr 21, 2017 | 12:25 PM
jasondeloy's Avatar
jasondeloy
Hey all, any help would be really helpful here.
Giving engine code that 6th cylinder is faulty. Replaced it twice. Replaced ECM
with factory new. Van continues dying (all dead, electrical, engine) at random
intervals. Sometimes while accelerating, sometimes when starting up,
sometimes slowing down and in idle.
Old Apr 22, 2017 | 07:26 AM
Wildman25's Avatar
Wildman25
Start with this Link, great trouble-shooting guide.
Some of the trouble-shooting cover the 4.6 / 5.4 from '97-'02, but in general most of the sensors remained the same up to '08+.
When you say "..... (all dead, electrical, engine)...." do you mean the engine just turns off, or you have no dash lights, no electrical power?? That would be related to the battery cables, and especially the ground cables/connections.
Also.......from the above link, read the topic on Page 4......No Start Due To Voltage Drop (Case Study)
Old Apr 22, 2017 | 09:01 AM
jasondeloy's Avatar
jasondeloy
Thanks!
The engine turns off, dash and all electrical go out. It occurs more frequently accelerating from a stop (stop sign, etc.). But has also occurred while going 40mph+, and immediately after turning the car on (cold or warm start).
Have changed the 6th coil twice, along with plugs, fuel filter, and now ECM, all based on different mechanics recommendations.
Wouldn't the ground cables be the first thing they check?
thanks for the response
Old Apr 22, 2017 | 10:48 AM
Conanski's Avatar
Conanski
Yeah if you lose all electrical power you have a global problem like a broken battery cable or a faulty ignition switch, this could be hard to find but start by checking all electrical connections.
Old Apr 23, 2017 | 12:10 PM
Wildman25's Avatar
Wildman25
Originally Posted by jasondeloy
Thanks!
Depends on who is working on it, and how busy the shop is, some shops Hate to work on electrical problems.
If all power goes out, including the dash, then it would lead back to a bad battery cable, most likely the ground cable, or even a bad battery? Bad battery cable connector?? Could you get a "load-test" on the battery from some shop?
Old Apr 24, 2017 | 10:35 AM
jasondeloy's Avatar
jasondeloy
Thanks for the feedback. So they say they check the battery cables, but I have my doubts. I get the feeling that the shop may be too busy to continue trouble shooting, so I might try my hand at diagnosing.
A few other facts from the weekend. Up until Saturday it was mainly my wife that has been driving. I drove it and experienced the van dying at 30 mph while slightly accelerating .
Then Sunday, after pulling out from a stop sign, going about 20 MPH, I felt the power dip, and the engine started stalling. I revved the gas and it maintained 20MPH, but wouldn't shift lower, or higher. In fact, I kept the pedal to the floor and it didn't accelerate at all, it did nothing. I was able to coast into the parking lot and then put it in park. it was idling rough and died in park. Restarted fine, and drove okay for the next 30 minutes.
Strange?
Old Apr 24, 2017 | 06:58 PM
Wildman25's Avatar
Wildman25
From your last post, I think it's time to get some codes pulled from the OBD II system, to see if any thing comes up.
You went from complete electrical shut down (OP), to lack of power/stall.
Your last post points to maybe a problem with the fuel pump/filters, that would cause the problem you experienced.
Get to a shop that has the full Diagnostic scanner, not from a parts store that will read the codes for free, Big difference.
Koremark
Sep 12, 2017 09:53 PM
Butch5
Jan 27, 2016 03:25 PM
dangitsbrandon
Jul 15, 2013 03:08 PM
jonmdon
Electrical Systems/Wiring
Oct 5, 2009 06:37 PM
mscott2154
27
Jul 17, 2006 04:43 PM
