Loss off electric power.
Old 12-25-2015, 02:54 PM
Butch5's Avatar
Butch5
Butch5 is offline
Hi guys,
I was wondering if anyone has an idea of what might be going on with my 95 e250. I was driving at highway speed when the van banged like a hard shift then I lost all electrical power briefly. The power came back on after a second or two and went off again. I pulled over and shut the van off. I tried to start it and nothing. I popped the hood and wiggled the battery cables and tried to start it again and it started. The lights were initially bright but then dimmed. I figure it was an issue with the cables. I found the positive cable had some corrosion so I clipped the end, cleaned it and the terminal and also cleaned the negative cable. The van starts and runs but the lights are dim and the gauges are maxed out. Also if I try to drive it it shifts hard and sometimes the engine will rev up before shifting making it shift hard. I suspect some sort of grounding problem but am not sure what to look for, any ideas would be greatly appreciated.
Old 12-25-2015, 03:29 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Start by getting your meter out and measuring the following:
1. Battery voltage at rest, everything off.
2. Battery voltage, ignition off, headlights on. Also observe and report headlight function.
3. Battery voltage at idle.
4. Battery voltage at 2000 RPM.
That will get us started.
Old 12-26-2015, 07:08 PM
Butch5's Avatar
Butch5
Butch5 is offline
Hi projectSHO89,
Sorry for the delay. It's been raining here and I had to work today. Here is what I got from the meter
Everything off 12.91 volts
everything off except headlights 12.52 volts. Lights are dim
Idle with everything off 14.29 volts
I didn't have a tach so I revved the engine slightly over idle and got 14.34 volts
Thanks for your help.
Old 12-31-2015, 12:30 PM
Butch5's Avatar
Butch5
Butch5 is offline
Originally Posted by Butch5
Hi projectSHO89,
Anyone have any ideas?
Old 12-31-2015, 10:26 PM
projectSHO89
Sorry, this got lost over the holiday. I'll look into it a bit in the morning, been driving all day...
Old 01-01-2016, 04:59 PM
projectSHO89
The good news is that the charging system appears to be okay.
If you're using aftermarket replacement battery cable clamps, make sure the part where they're supposed to connect with the bare cable are actually clean, not painted. Check all your grounds, starting at the battery cable. Check the ones on the upper and lower radiator supports, the engine side of the firewall, and inside the cabin up under the dash (near the gas pedal). See what all those look like.
Old 01-01-2016, 09:31 PM
Butch5's Avatar
Butch5
Butch5 is offline
Ok thanks, I'll check them. I came across a thread where someone had the same symptoms that my van has. In that thread they suggested changing the vss. I did that but it didn't resolve the problem.
Old 01-01-2016, 10:16 PM
projectSHO89
I do not know why there would be any expectation that an electrical supply issue would be affected by a VS sensor.
Old 01-02-2016, 04:38 AM
Butch5's Avatar
Butch5
Butch5 is offline
I think it was because of the hard and erratic shfting. Also because the speedometer doesn't work and the gauss are haywire. I had just done a Google search when it happened and that thread came up.
Old 01-27-2016, 11:41 AM
Butch5's Avatar
Butch5
Butch5 is offline
Hi projectSHO89,
Hey, it was a ground wire at the battery. It was a small wire from the battery to the body. I saw it but thought it was something left from another installation. Thanks for you help, I appreciate it.
Old 01-27-2016, 02:45 PM
projectSHO89
Thanks for coming back and following up. Glad to be of service.
Old 01-27-2016, 03:25 PM
Butch5's Avatar
Butch5
Butch5 is offline
Actually, I just found it today. It's the first I've tried to work on it. It's been raining and cold and I've been busy. I actually looked at that ground wire when it happened and thought it was an old wire from something someone had done in the past.
Thanks again, it saved me some money!
bri687
13
02-22-2018 07:35 PM
Billski
1983 - 2012 Ranger & B-Series
07-05-2016 10:02 PM
UnklRiko
09-24-2009 08:49 PM
-jeremy
Electrical Systems/Wiring
11-09-2004 09:30 AM
jpsartre12
12-14-2003 07:10 PM
Quick Reply: Loss off electric power.
