Strange electrical problem
Old Sep 4, 2017 | 10:19 AM
Koremark's Avatar
Koremark
Howdy.
Have a F-250 inline 6.
After Hurricane, drove the truck for a few miles no problems started fine ran fine.
after after all that rain passed ,
went out and tryied to start it, nothing.
Put another good battery on it Nothing no dash lights, no lights at all.
Tried to Jump start it the dash light up, just the small Car was not strong enough ?
replaced the Solenoid, same thing battery at full charged,
not sure if it is Starter or maybe Ignition switch?
Thank you Help and Guidance in this matter.
God Bless
Old Sep 4, 2017 | 10:35 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Start by checking both ends of your battery cables. Both positive and negative. Clean up any corrosion an loose connections.
Did your truck become submerged at all?
Old Sep 4, 2017 | 10:37 AM
subford's Avatar
subford
Sounds like the battery cables.
Bad connections at the battery, solenoid or at the engine block ground of the cable.
What year is your F-250?
Old Sep 4, 2017 | 01:42 PM
mrollings53's Avatar
mrollings53
His profile says 1992 F250.
Second checking the cables. I just had the same problem on my truck. The inside of the positive cable terminal was black with corrosion.
Old Sep 4, 2017 | 10:30 PM
Koremark's Avatar
Koremark
Sorry my Bad, Truck is a 1992 F-250, Naw it was on High ground
Yep keep my Connections clean at the Battery,
Will check the Cables more closely.
Will up date by this thursday,
Old Sep 12, 2017 | 06:19 PM
jtmalott's Avatar
jtmalott
What did you find?
Old Sep 12, 2017 | 09:53 PM
Koremark's Avatar
Koremark
Sorry for the length of time for the Update.
Fender ground was not connecting and load tested the batteries and they test at 5.
so in short low amp Batteries and a bad ground.
Thank you for all your wisdom and Guidance.
evan_nugget
Nov 20, 2017 12:37 PM
James Hiller
19
Mar 26, 2014 07:24 AM
79 bronc
Electrical Systems/Wiring
Aug 10, 2010 10:55 AM
RAK1
Nov 23, 2003 06:35 PM
iamme9182
Sep 26, 2003 04:33 PM
