Sponsored by: Real Truck
F250 height
Old Apr 21, 2017 | 10:16 AM
RomeoKilo's Avatar
RomeoKilo
4wd Low
F250 height
I'm looking at a 2016 crew cab lariat, 20" wheels, snow plow springs and roof lights. My parking garage at work says 7' clearance. In my current 2012 f150 with 20 inch wheels and 33" duratracs my antenna hits at one spot when exiting the garage. Do you guys think the f250 would fit?
Old Apr 21, 2017 | 11:30 AM
Misky6.0's Avatar
Misky6.0
Ford specs on-line, show the 2016 is 79.7 (essentially 80 inches).
84 inches is 7 ft.
Not much margin for error, nor if I'd trust the 7' nor 80 inch figures either.
Snow plow prep might give you a bit more height up front - which isn't accounted for in Ford's figure either.
When going between floors with a long wheelbase vehicle you may encounter a ceiling beam in just the wrong place will hit - especially on a curve.
My 2WD excursion has touched a low beam on a curve inside a parking garage - on the way out - no sign of damage - but it sure made me nervous.
Plus the antennae sticks up 4-6 inches ABOVE my roof - and it's had the last few inches of paint removed from hitting parking garages.
Old Apr 21, 2017 | 11:46 AM
kcducttaper's Avatar
kcducttaper
Bring a tape measure.
Old Apr 21, 2017 | 11:59 AM
RomeoKilo's Avatar
RomeoKilo
4wd Low
Yeah I'm going to take a tape and measure a bunch of areas I suppose. I don't have to go any farther than ground level. I know there is a guy in there with a 7.3 with a leveling kit but it looks smaller than the newer trucks I've seen.
Old Apr 21, 2017 | 12:12 PM
kcducttaper
The new trucks do seem to be bigger than the older ones. I don't know why they keep making them bigger like that. My '99 is plenty big and awkward enough as it is. Go figure...
Old Apr 21, 2017 | 02:08 PM
seville009's Avatar
seville009
My 2011 F350/Excursion with a roof luggage rack and 18" Duratrac tires measured at 82".
Old Apr 21, 2017 | 06:46 PM
fire240's Avatar
fire240
I know with my truck 7'2" is a bit snug. Only a few inches between the roof of the cab and the ceiling of the parking area.
kxriderforlife
Dec 13, 2018 02:05 PM
hikeril
6.7L Power Stroke Diesel
May 4, 2015 11:30 AM
hoss66
Apr 7, 2015 10:28 AM
bbender85
Michigan Chapter
Dec 11, 2007 07:26 PM
Ford_Girly
Oct 14, 2002 03:46 PM
