Oil cooler issue
Old Apr 21, 2017 | 09:42 PM
Tideman's Avatar
Tideman
I just paid $310.00 @ white bear lake Ford. Full kit.
Old Apr 22, 2017 | 05:47 AM
bismic's Avatar
bismic
Originally Posted by Oh no 6.0
navistarnut, I wasnt able to find any threads on this topic.
That being said, guess its time to go to ford and get an OEM.
I am really curious thou, where do you guys think the oil could be entering the water since the water inlet and outlet stick outside the housing. Isn't that the only place?? It must be getting past those two Orings??
Thanks for all the input
Remove the cheap one and tear it down/apart (some people have cut/sawed one in half to inspect). It is interesting to see how they are constructed and where the weak points are. The leak is probably between plates as DarkStarMedia said.
Old Apr 22, 2017 | 09:24 AM
53jimc's Avatar
53jimc
Originally Posted by Tideman
Saw you flushed with mineral spirits. What you may be seeing is some of the residue left over from the flush. Just keep a close eye on it.
Edit; sorry that was 53jimc post not yours.
Yep, mineral spirits did the trick. I did flush a long time and made sure it was all out before I put good water and Rotella ELC coolant in it. It has been oil free since last September.
Oh no 6.0
Apr 21, 2017 11:33 AM
genscripter
42
Aug 23, 2015 02:29 PM
vtown00
21
Feb 12, 2015 08:13 PM
acf6
Feb 14, 2013 08:05 AM
dzzavid
Oct 1, 2009 05:14 PM
