rebuild time
Old Apr 20, 2017 | 09:34 PM
reebadoo's Avatar
reebadoo
Talking rebuild time
Im finally starting to tear down my 400 and im looking for advice on parts and what all i should have done. right now i have a performer intake and holly 1850 and a new crane h-260-2 . the rods and crank look good but i need bearings and pistons, i have a set of heads that are polished and ported and milled .030 as far as i know. i picked up an engine that i can cannibalize and it is bored .060 over i think, at least thats what it says on the pistons. im not sure if its a 351m or 400. but some parts are interchangeable. any suggestions and ideas for the build?
Old Apr 20, 2017 | 09:41 PM
reebadoo's Avatar
reebadoo
Old Apr 21, 2017 | 07:37 AM
Gary Lewis's Avatar
Gary Lewis
You will soon find that there are basically two sources for pistons: Tim Meyer if you want good compression, and anyone else if you are satisfied with 8:1. I recommend Tim's pistons. In fact, I had him do the assembly work on the engine and then dyno it.
Old Apr 21, 2017 | 09:34 AM
reebadoo's Avatar
reebadoo
i am looking at the KB2347 the 13.3 cc pistons. and with the milled heads im wondering what the cr would be. what brand of bearings to use? which brands and special bearings that will work best for the engine. i just don't want all my work to go up in smoke!
Old Apr 21, 2017 | 04:51 PM
Gary Lewis's Avatar
Gary Lewis
Tim is the foremost 335 Series guy in the world. He builds them all the time, so tell him what you have and ask for his advice on pistons. You'll probably have to leave a message as he gets many, many calls for help and can't answer the phone for every call. But, leave him a message, tell him what you need, and he'll call you back. But buy as much as you can from him as we need him to stay in business. Where else can we get pistons? So I bought bearings, gaskets, cam, etc from him. And, by the way, you should do his mod to the oiling system: Oiling System Mod's - ???Gary's Garagemahal
Old Apr 21, 2017 | 09:20 PM
reebadoo's Avatar
reebadoo
maybe we can get him to chime in, i will be doing the building myself but i will have a shop clean up the block and heads, i can install and do everything else myself given the time.
Old Apr 21, 2017 | 10:44 PM
Gary Lewis's Avatar
Gary Lewis
I wouldn't hold my breath. I would call him.
Old Apr 21, 2017 | 10:56 PM
reebadoo's Avatar
reebadoo
okay, do you have any ideas of what milling .030 off the heads will change the chamber size?
Old Apr 21, 2017 | 11:03 PM
Gary Lewis's Avatar
Gary Lewis
No, I don't. I bought a burette years ago and measured mine, so you could do that and know exactly what volume you have.
Old Apr 24, 2017 | 02:13 PM
reebadoo's Avatar
reebadoo
i will have to figure something out then, do you have any idea what the tag that says (p rm-2 126077) means? im so confused about it
Old Apr 24, 2017 | 04:18 PM
Gary Lewis's Avatar
Gary Lewis
I'd bet that's a re-builder's tag. No idea what the first part means, but the 126077 is probably the odometer reading when it was installed.
Old Apr 24, 2017 | 08:38 PM
reebadoo's Avatar
reebadoo
how do they know when there are 100000 miles when the odometer has 5 places not 6?
it also has the number stamped into the bottom of the block around the oil pan gasket
Old Apr 24, 2017 | 08:39 PM
Gary Lewis's Avatar
Gary Lewis
They probably asked the owner.
Old Apr 25, 2017 | 09:39 AM
reebadoo's Avatar
reebadoo
alright, thank you.
Old May 16, 2017 | 09:58 PM
reebadoo's Avatar
reebadoo
i have a little update. its going to be a long project. but i was cleaning up the pistons and it has B 040 on the top of the piston. so i guess its been built up just a little. so what should i do when this has a pretty big lip and im not sure how much more i can take off safely.
