Engine Squeal
Old Apr 20, 2017 | 07:55 AM
mtbraun's Avatar
mtbraun
Engine Squeal
Some background: 400 in a 1969 F100, been in storage for about 20 years. I changed the oil, and reprimed the system until there was oil lubricating valve train through the push rods. Got it fired up and noticed a very loud squeal from engine. One by one, I unhooked the following to identify the source: power steering pump, alternator, fan/water pump. Squeal still there, unfortunately. Could this be a cam or crank bearing? I'm hoping its not something major but am not confident at this point.
I read where bad vacuum lines can cause a squeal, but this noise follows the RPM range - gets louder with more RPMs. Its really tough to narrow down exactly where it is coming from, but it appears to be the front of the engine.
thanks.
Old Apr 23, 2017 | 11:18 AM
artscott61's Avatar
artscott61
Veteran: Navy
A friend had a crate motor from a national supplier and his squealed at low r p m's it was a chevy but still same. Turned out to be cam bearings and maybe cam the well know company would not do a thing the only good that came out of this he swore off chev's if he would have kept the truck he was going to put in a 302ford I wish that had happened.
Old May 1, 2017 | 07:24 AM
mtbraun's Avatar
mtbraun
So thankfully this turned out to be a vacuum leak. I've never heard a vacuum leak like that, but glad it was something simple.
Old May 2, 2017 | 02:05 PM
kopfenjager's Avatar
kopfenjager
awesome you fixed the problem and than finished off the thread with the solution. So many times I have done a search, got to the end of a thread and no solution. Its a real bummer! A vacuum leak you say, must have been one hell of a leak to sound like that.
RV_Tech
Nov 4, 2016 02:19 PM
dharte
Nov 1, 2014 06:28 PM
tatonka
Jan 21, 2014 06:14 PM
lzrj
Aug 5, 2009 07:52 PM
Donny Q
Dec 2, 2006 01:17 PM
