Vacuum Leak
Old Jan 20, 2014 | 08:54 PM
tatonka's Avatar
tatonka
Vacuum Leak
Guys, I have a 91 ford f150 5.0 engine. engine idles about
1500 rpm. I think I found a vacuum leak at the diverter valve
behind the intake. would this cause the engine to idle high?
Old Jan 21, 2014 | 02:43 PM
White Max's Avatar
White Max
Yes, a vacuum leak can cause a high idle.
Old Jan 21, 2014 | 06:08 PM
tatonka's Avatar
tatonka
that looks like a major job to change. if I take the smog pump off will that
fix the vacuum leak coming from the air diverter valve?
Old Jan 21, 2014 | 06:14 PM
rla2005's Avatar
rla2005
No it will not.
RV_Tech
Nov 4, 2016 02:19 PM
75N
Mar 17, 2015 11:42 PM
dharte
Nov 1, 2014 06:28 PM
inspector1
Feb 19, 2008 07:26 PM
