IPR wire connector
Old Apr 19, 2017 | 08:04 PM
jimzpsd's Avatar
jimzpsd
IPR wire connector
With a no start situation, I noticed my IPR wires (2) were missing the first four inches of insulation from a fuel leak. The bare wires were touching each other and possibly ground too. Plus upon unplugging the connector, the plastic housing that mounts to the solenoid broke off in pieces (fuel contamination)All this would definitely cause a no start......correct?
Old Apr 19, 2017 | 08:08 PM
tshrager's Avatar
tshrager
Yes it will. I would replace IPR and pigtail with motorcraft Only.
I didn't see the pigtail, but I'm sure he has it, riffraff sells the re seal kit that might do the trick. I have no way of telling how bad your IPR IS.
Old Apr 20, 2017 | 08:45 AM
jimzpsd's Avatar
jimzpsd
A new ipr is already in and I used an old injector solenoid connector soldered onto the existing ipr harness.
Old Apr 20, 2017 | 10:45 AM
jacob_powerhouse's Avatar
jacob_powerhouse
i had a similar issue but it was from corrosion in which i removed a section of the bad wire and soldered in a new piece then shrink wrapped it. i highly recommend investing in a soldering kit.
dchamberlain
Apr 25, 2023 11:18 PM
ckutter
Mar 28, 2014 06:56 AM
MONAVIERONJON
Aug 12, 2013 08:32 PM
Jwhitman
Aug 20, 2012 08:21 PM
fordfan66
1978 - 1996 Big Bronco
Feb 13, 2007 09:20 PM
