AE connecting trouble
Old Apr 19, 2017 | 04:17 PM
DND58's Avatar
DND58
Has been some time since connecting. Version 13.2.4 Giotto. "Tool was unable to detect on launch. Any ideas? On road, will check back.
Old Apr 20, 2017 | 07:15 AM
Tugly's Avatar
Tugly
It helps to make sure the protocol is set to J1850 PWM. Make sure your cigarette lighter fuse is not blown. There is one other fuse that can prevent the OBDII port from working, but I can't recall where that thread was - nor can I recall if that blown fuse to the OBDII port prevented the truck from starting.
Old Apr 20, 2017 | 09:25 AM
DND58's Avatar
DND58
Thanks Tug. Problem was loose connection at Proline connector. 1211 code. Was not into it that hard with PHP 65 tow. I did not notice power loss. Will look at ICP connectfor for oil. Other suggestions?
Old Apr 20, 2017 | 04:52 PM
Tugly's Avatar
Tugly
Look at the fuel injector pulse width - see if it goes over 3 ms when you get on it.
Icicle
May 30, 2014 02:37 PM
jdcunn99
Mar 16, 2013 10:32 AM
ntputter17
Mar 14, 2009 10:56 PM
BigJohn64
Computer Chips & Tuners
Mar 9, 2003 03:23 PM
