Computer Chips & Tuners
Microtuner 1715
Old Mar 5, 2003 | 07:11 PM
BigJohn64's Avatar
BigJohn64
Microtuner 1715
I just recieved my 1715 in the mail,plugged into slot and nothin,I'm I doing something wrong or are there more than one slot,also I wanted too verify the right fuel pump fuse.I have a 2000 X 4x4 v8.Thanx for any help.
Old Mar 7, 2003 | 05:41 PM
FTE Ken's Avatar
FTE Ken
Microtuner 1715
Which fuse did you pull?
Sounds like you've killed power to the OBD connector, possibly pulling the wrong fuel. This is the only reason why it wouldn't work because its powered by the port.
Old Mar 7, 2003 | 10:57 PM
BigJohn64's Avatar
BigJohn64
Microtuner 1715
Ken,I talked to superchips the other day and the cigarette lighter fuse runs the tuner,a
and they said if that was blown that would keep it from powering up.I ck fuse it was blown problem solved.Thanx I pulled fuse #112 for the fuel pump.
Old Mar 9, 2003 | 03:23 PM
FTE Ken's Avatar
FTE Ken
Microtuner 1715
That's why I asked about the fuse. I thought maybe you pulled the lighter fuse (if you check elsewhere in this forum you'll see where I've recommended the lighter fuse as the problem). Few people use the cigaretter lighter these days so often they don't even know its blown.
