code P1670, PCM?
Old Mar 8, 2013 | 08:14 PM
jdcunn99's Avatar
jdcunn99
code P1670, PCM?
Hey, my 2000 f-250 superduty has recently been shutting off while going down the road. You wait a little while and the truck starts back, I'm getting a P1670 code. I'm not sure but does that point to the PCM? Also, when the truck dies, some of the lights on the dash do not illuminate such as the wait to start light, and the tow/haul light will illuminate in the "off" position. Anyone have any suggestions?
Old Mar 9, 2013 | 07:39 AM
white Buffalo's Avatar
white Buffalo
P1670= "EF Feedback Signal Not Detected"
Not familiar with this code. I would start with pulling the PCM fuse and see if the symptoms return.
Old Mar 15, 2013 | 06:38 PM
jdcunn99's Avatar
jdcunn99
Sorry took so long to reply, but you were spot on. The fuse was not blown, but it is not making a good connection inside the fuse block. When you wiggle the fuse, I believe in the # 30 spot in the inside fuse compartment, the truck dies, or it kills power to the PCM. I didn't know what else to do, so I stuck a tooth pick under the fuse to give it better connection and the truck has ran fine since. Any suggestions?
Old Mar 16, 2013 | 10:32 AM
white Buffalo
I guess I would remove the keys, disconnect the batteries and try 2 options:
1. squeeze the fuse connectors tighter so they hold the fuse in place.
2. or if it is the wire behind it coming loose you could try and solder it on.
or option 3: leave the toothpick in place for now - it works!
But there are others on this forum that have had to do some minor repairs to their fuse panel. They would be better off answereing this question.....
Glad you found the problem!
Rich
lostislandguy
15
Mar 8, 2023 01:04 PM
Reefmonster
Jan 9, 2010 12:15 PM
jamie chappell
Electrical Systems/Wiring
May 2, 2008 12:27 PM
toturdriver
May 12, 2004 03:39 AM
