what does this do ?
Old Apr 19, 2017 | 04:14 AM
vemax's Avatar
vemax
what does this do ?
hi all
does anyone know what this white unit does and what's it called .
its coonected to the above black box .
it has 2 vacume plugs but it only has one vacume connected ,
the small black plastic container had a loose wire that wasn't connected to anything,
its a f100 1986 XLT.
i snapped off the vacuum hose
thanks
Old Apr 19, 2017 | 06:39 AM
reamer's Avatar
reamer
Waay to close to figure location, Zoom out.
Old Apr 19, 2017 | 08:08 AM
vemax's Avatar
vemax
sorry about that,
the white unit its directly under the glove box and the other directly behind the glove box.
hope that makes sense .
ill post more pics soon
Old Apr 19, 2017 | 08:19 AM
Gary Lewis's Avatar
Gary Lewis
Ok, are you the one in Oz? I ask because there was no such thing as an F100 in '86 in the US or Canada. And that white thing doesn't look like anything I've seen on these trucks.
Old Apr 19, 2017 | 08:51 AM
vemax's Avatar
vemax
yea its weird ,i looked everywhere on repair manuals and nothing came up.
i thought it was the same as f150 in the us
Old Apr 19, 2017 | 08:58 AM
Gary Lewis's Avatar
Gary Lewis
So, you are in Oz? Would you, please, put that in your info in the user control panel so we don't have to ask every time?
Your HVAC system appears to be quite different from ours. But, are you sure that is a wire and not a hose? If it were a small vacuum hose it could connect to the white thing. However, I don't know what the white thing is. I see that the top screw slot appears to be elongated for adjustment. Have you pulled it off to see if there is something behind it that moves it?
Old Apr 19, 2017 | 09:16 AM
vemax's Avatar
vemax
definitely a wire . no adjustment just a plunger .
Old Apr 19, 2017 | 09:21 AM
Gary Lewis's Avatar
Gary Lewis
Thanks for the location info.
Does the air temp arm activate the plunger? Perhaps it provides vacuum to a shutoff valve in the water supply to the heater core when the temp is set to its coldest setting. Check the heater hoses for a vacuum-controlled valve.
Old Apr 19, 2017 | 09:30 AM
vemax's Avatar
vemax
yes i think your right , but i dont know what its called so i can buy one.
Old Apr 19, 2017 | 09:37 AM
kr98664's Avatar
kr98664
Can't help with the part identification, but I do speak fluent Australian and will gladly assist with any language issues.
Old Apr 19, 2017 | 09:42 AM
Gary Lewis's Avatar
Gary Lewis
I would guess it is a cold air valve, or something like that. We don't have them here, but sure wish we did as we have hot water flowing through the heater core at all times, and that makes the Max A/C and Vent positions warmer than they need to be. So, if you find out maybe we can incorporate them?
Old Apr 19, 2017 | 09:45 AM
kr98664's Avatar
kr98664
If you can't find a replacement, can the existing hose barb be repaired?
On other vehicles with similar damage, I'd carefully drill a short way, stopping well short of the internals. Then fit a short piece of brass tube to create a new hose connection. Secure the new brass piece with epoxy on the outside only, and you're good as new. I've done this several times on vacuum parts that were otherwise unobtainable.
Old Apr 19, 2017 | 09:51 AM
Gary Lewis's Avatar
Gary Lewis
Or, just epoxy the plastic piece back on, making sure that no epoxy gets inside.
Old Apr 20, 2017 | 04:26 AM
vemax's Avatar
vemax
thanks for the advice ,
i need to dig deeper, as long as the aircon is operational by summer im happy.
hjscm
2015 - 2020 F150
44
Aug 19, 2015 12:43 AM
Bernie Lomax
Nov 26, 2007 01:31 AM
Duceswild
Nov 7, 2007 12:28 PM
phoneman91
Mar 21, 2005 05:59 AM
ChevmaninaFord
2004 - 2008 F150
30
Jan 31, 2005 09:14 PM
