Transmission cooler lines
Old Apr 18, 2017 | 09:35 PM
D Craig's Avatar
D Craig
06 6.0
How do I remove the trans cooler lines from under the truck? I've got the lines hanging free they're unscrewed from the transmission and trans filter but I can't seem to snake them out to replace them. How is this accomplished?? Thanks for the help
Old Apr 18, 2017 | 09:46 PM
Tideman's Avatar
Tideman
I believe there is a bolt to the frame holding them in place. It may be on the cross member beside the engine. Sorry not much help but they are fastened on.
Edit. Here's a picture
Old Apr 18, 2017 | 09:58 PM
Tideman's Avatar
Tideman
Looking at this, it's bolted to block. I couldn't remember.
Old Apr 19, 2017 | 12:18 AM
TooManyToys.'s Avatar
TooManyToys.
From the service manual:
Remove line attachment nuts (4).
Remove bolt, cooling lines retaining clip.
Remove engine. For additional information, refer to Section 303-03.
To install, reverse the removal procedure.
Tighten attachment clip bolt to 18lb-ft.
Tighten cooling line nuts to 12lb-ft.
It's just a pain to work those out of there.
And I made up the torque values.
Old Apr 19, 2017 | 07:05 AM
D Craig's Avatar
D Craig
I'm aware of the 10mm bolt that attaches the cooler lines to the frame, ive unbolted those. I can't figure out how to snake it through the frame and exhaust and get both lines out. Removing the motor is not an option at all it seems silly you'd need to drop the motor for 2 small lines
Old Apr 19, 2017 | 07:20 AM
TooManyToys.
That was a joke because of Tideman's picture.
Many have struggled getting them out. Appearantly it can be done, I didn't bother. I cut mine so the lines acted as nipples and used transmission hose to replace them.
Old Apr 19, 2017 | 12:20 PM
Tideman's Avatar
Tideman
WHAT!?!? you mean to tell me I didn't have to take the engine out to get em out. Dang!!
Old Apr 19, 2017 | 12:44 PM
TooManyToys.
I guess I should have told you earlier.
ChristopherN
Feb 18, 2012 07:58 PM
rileyruffen
2004 - 2008 F150
Mar 11, 2011 11:20 PM
bigdaddys99
Dec 19, 2009 06:02 PM
Blast Chamber
Aug 20, 2009 04:39 PM
kvb78
Apr 15, 2004 11:54 PM
