Intercooler installation problem
Old Apr 18, 2017 | 09:22 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Hey guys, I'm having trouble getting my intercooler installed on my truck. The driver's side pipe is hitting my ac line, and I can't get either one to coexist happily.
E99 spyder and pipes, 6.0 intercooler
Old Apr 18, 2017 | 09:31 AM
fordman67's Avatar
fordman67
Bend and tweak.all I can say
Old Apr 18, 2017 | 09:42 AM
Jarrett Campbell
That's what I was afraid of. Just wanted to make sure there wasn't a super secret way to do the job before I started bending lines.
Old Apr 18, 2017 | 09:45 AM
fordman67's Avatar
fordman67
The ac line between the rubber and condenser is aluminum and bends very easy.
Old Apr 18, 2017 | 09:57 AM
BBslider001's Avatar
BBslider001
Just be VERY careful not to bend back and forth too much. Try to eyeball as much as you can and have a plan of where you want it to go, then bend it. Aluminum break easy when you go back and forth with it.
Old Apr 18, 2017 | 09:59 AM
oldbird1965's Avatar
oldbird1965
I bent mine a little and then put a piece of rubber between the ac line and IC pipe for a cushion.
Old Apr 18, 2017 | 11:11 AM
dclack's Avatar
dclack
Yep, I had to bend mine too. I also had to bend the power steering line a little to get it out of the way, and I had to cut and move the post coming off of the battery tray that holds the air box in place. If you have a 6637 and no air box, then just remove it. You can kind of see how mine fits in these pics... https://www.ford-trucks.com/forums/1...l#post16599815
Old Apr 18, 2017 | 11:16 AM
dclack's Avatar
dclack
A couple more pics here... https://www.ford-trucks.com/forums/1...l#post16635971
Old Apr 18, 2017 | 01:18 PM
Jarrett Campbell
Cool. Thanks guys! I'll rep when I'm at a computer.
Old Apr 19, 2017 | 10:08 AM
Jarrett Campbell
One more thing... What's the plug size for the big hole on the spyder?
Old Apr 19, 2017 | 10:24 AM
dclack's Avatar
dclack
It is either 1/4" or 3/8" NPT, can't remember for sure. I used the plug from the side of the water pump in mine. It's the same size. Plus I drilled and tapped the two hose fittings for 1/8" NPT; one got a plug and the other got my boost gauge.
Old Apr 19, 2017 | 10:28 AM
Jarrett Campbell
I'll get one of each. Thanks Darrin!
Old Apr 20, 2017 | 01:19 PM
Jarrett Campbell
I got everything installed, just need two more hose clamps and the pipe plug and I will be good to go!!
Pics will be posted in my build thread.
tractormanbill
36
Apr 9, 2018 11:18 PM
benbuilder
Aug 11, 2016 05:44 PM
98GP
Sep 18, 2014 08:23 PM
esauls09
Jun 22, 2010 10:26 PM
thordehr
May 25, 2010 10:34 PM
