The windshield wiper on my 2001 f150 has stopped working.
Does anyone know how to troubleshoot what the cause is.
Would it not have to be either the switch (in the turn signal lever) , a fuse, a rellay or the motor.
I'd obviously prefer not to have to replace everything.
Hope all is well and hope to hear from someone soon.
Does the washer work ? Or both washer and wiper failed ?
By your left knee, inside the fuse box , fuse #11 is for washer / wiper and other.
Under the hood on left fender well, fuse #202 or 209 power the motor and speed control relay.
If all fuses have power, I would check at the motor, and if no power, then look into the multi switch...... do you have other problems with the power at switch ? Do you use the TILT WHEEL often ?
