I'm leaking oil. Help!
Old Apr 16, 2017 | 09:37 AM
anolog139's Avatar
anolog139
Last night I noticed oil on my driveway. I got up under my truck and it was dripping at the trans. I'm not sure that's where it's actually leaking from because the other side of the oil pan had clean oil on the outside of it. Anyone have any idea what this could be?
Old Apr 16, 2017 | 09:57 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
How is your oil level?
Old Apr 16, 2017 | 10:05 AM
anolog139's Avatar
anolog139
Oil level is good. Still full
anolog139's Avatar
anolog139
but I've never noticed a leak before on the concrete
Old Apr 16, 2017 | 12:35 PM
WatsonR's Avatar
WatsonR
Check under the turbo.
Old Apr 16, 2017 | 02:57 PM
anolog139's Avatar
anolog139
from what I can tell it looks normal. I just drove it again and nothing as dripped but where the trans lines up and the oil pan are still wet with oil
Old Apr 16, 2017 | 02:58 PM
anolog139's Avatar
anolog139
Old Apr 16, 2017 | 06:02 PM
Blakshukvw's Avatar
Blakshukvw
Mine had oil there and I just replaced my icp sensor and it was leaking into the plug and all over the back of my engine. My 6.0 is an 03 though. Late 04 and up the icp is on the valve cover and probably wouldn't leave oil there. Could possibly be the ipr though since its on the pump cover.
Old Apr 17, 2017 | 04:25 AM
Mcrafty1's Avatar
Mcrafty1
Rear main seal starting to seep? I know nobody wants to go there but...That is whats directly above the oil leak you picture.
Old Apr 17, 2017 | 05:23 AM
bismic's Avatar
bismic
Almost every oil leak on a 6.0L ends up on the bell housing.
The OP needs to tell us what year model his truck is.
Also, I believe there is an oil leak thread in the Tech Folder. If not, I have some links saved.
Old Apr 17, 2017 | 08:20 AM
navistarnut's Avatar
navistarnut
He was looking at an 03 last month, not sure if this is the truck or not. If so could easily be the ICP
Nobody else here wonders what the gasket maker is doing on the pan plug?
Old Apr 17, 2017 | 08:42 AM
2006powerstroke90's Avatar
2006powerstroke90
I thought it was bubble gum
Old Apr 23, 2017 | 10:52 PM
anolog139's Avatar
anolog139
hey it's a 2006 king ranch
Old Apr 23, 2017 | 11:14 PM
87crewdually's Avatar
87crewdually
Stand on a stool with a bright light and look in the valley of the engine. Like said, check the tech folder. There's a few opportunities for leaks up there that all end up dripping where yours is.
You may need to wait until the engine is cold and degrease it and hose it free from oil. Then run it and check for the source of the leak. Could be HPOP cover, oil pressure switch, oil cooler cover, oil filter housing, turbo drain, turbo feed, turbo to CAC hose, ect....
Jacobhudson125
Oct 17, 2018 06:24 PM
Audacious
Sep 29, 2018 07:50 PM
evan_nugget
Apr 6, 2018 06:36 AM
hharris8
162
Aug 26, 2016 02:48 PM
bigmike09
Oil & Lubrication
Oct 6, 2003 10:37 AM
