Sponsored by: Auxito
A.c. problems
Old Apr 15, 2017 | 09:40 PM
99fordf1502wd's Avatar
99fordf1502wd
A.c. problems
I really need some help I have spent hours looking up and down this site and Google ingeneral. I just replaced my blend door and heater core on my 1999 ford f150. The blower blows the speed changes the blend door actuator rotates but I still have no air blowing in my vent. Any Ideas would be great spent many hours trobleshooting.
Old Apr 15, 2017 | 10:37 PM
steve(ill)'s Avatar
steve(ill)
the blend door is electric and variable position for temp control........ there are 3-4 different vacuum pistons that move OPEN- CLOSE to direct the air to your feet, dash, defrost or a combination of them.. If you loose vacuum, it gets stuck on defrost... if you can change directions of the air, but only loose the vents, then you could have a bad vacuum cylinder, plugged hose, or control **** port bad inside... look at the print below to see the vacuum cylinders.
Old Apr 15, 2017 | 10:39 PM
steve(ill)'s Avatar
steve(ill)
post #147 below .......... can you direct air to the floor or just defrost ?
https://www.ford-trucks.com/forums/9...-please-2.html
Old Apr 16, 2017 | 10:20 AM
99fordf1502wd
As far as I can tell all my vacuum lines are good. I started my truck this morning heard a clink clank noose like the vacuum moved a door and it started to blow some air through all vents on max ac. I'm wondering if something is causing the doors to not open all the way is there a way to access them?
Old Apr 17, 2017 | 12:41 PM
steve(ill)'s Avatar
steve(ill)
they are various locations behind the dash.. you can "see" a couple by laying on the floor and looing up toward the radio. Might be able to get access by removing radio and dash in that area...... It is MORE COMMON to have loss of vacuum due to leaking hoses under the hood, or on the back of the control ****, or inside the controller itself ( leaking between ports) ............ doors are the LAST think to consider.. check vacuum.
Old Apr 17, 2017 | 12:55 PM
99fordf1502wd
I really appreciate all the information, I found my problem inside my dash next to the black box holding the blend door and heater core. It was the vent right above the blower motor it had broken and caused a vacuum so no air could come out. I thank you for all the information it allowed me to learn more about my truck!
Vinford
Jun 6, 2015 09:20 AM
TobyM
Nov 13, 2013 10:33 PM
shakebaker69
1997 - 2003 F150
Sep 3, 2013 06:13 PM
jessibrown
1983 - 2012 Ranger & B-Series
32
Sep 25, 2011 08:21 AM
mfhillz28
1997 - 2003 F150
Nov 24, 2007 07:53 PM
