dead on road
Old Apr 15, 2017 | 01:17 PM
farmer ford's Avatar
farmer ford
dead on road
just got a call from a friend who was driving and his truck died going down the road like the key was shut off. just a total loss of power. at first i thought maybe a cps but he just called back and the wts light doesnt even come on before cranking. is this do to a pcm or are they even related.
Old Apr 15, 2017 | 01:30 PM
BBslider001's Avatar
BBslider001
No WTS light and the symptoms point to a CPS. Ask him if the tach moves when cranking. Also, make sure to get a dealer or Motorcraft CPS, NOT a parts store replacement.
Old Apr 15, 2017 | 01:34 PM
farmer ford
10-4 for on dealer parts. i forgot about the tach, and didnt realize the wts light was related thanks and we will get a cps put in
Old Apr 15, 2017 | 01:41 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Also check fuse 22.
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Old Apr 15, 2017 | 01:44 PM
Red97350's Avatar
Red97350
X2 on what Jarrett said. I would also check fuse 22.
Red
Old Apr 15, 2017 | 01:46 PM
farmer ford
what all does #22 feed power to?
Old Apr 15, 2017 | 01:49 PM
Hussler's Avatar
Hussler
Originally Posted by Jarrett Campbell
X2 ^^^ check fuse 22. If blown unplug the fuel filter canister heater wire, put another fuse in 22 (30A I believe), common problem.
Old Apr 15, 2017 | 01:50 PM
Red97350's Avatar
Red97350
#22 feeds power to the PCM.
Red
Old Apr 15, 2017 | 01:56 PM
Hussler's Avatar
Hussler
Lots of things but most importantly the PCM and fuel filter canister heater. If the heater wire shorts inside the fuel bowl it blows fuse #22 and kills power to the PCM, thus no WTS light. IIRC it the second from top connector on drivers side on fuel bowl. Hard to remove because it's a spade type push on connector.
Old Apr 15, 2017 | 04:27 PM
BBslider001
Yup, what these guys said
Old Apr 15, 2017 | 05:06 PM
farmer ford
Thanks so much. Haven't dealt with that in quite a while it is almost a crutch to know I can turn here for help
john321
Jul 31, 2017 02:34 PM
cabloom300
32
Mar 13, 2013 07:14 AM
hink10
44
Mar 12, 2011 11:48 AM
ferret2
18
Jan 26, 2009 09:54 PM
dagren99
Oct 5, 2005 08:35 PM
