What are these things?
Old Aug 19, 2002 | 11:35 PM
the law's Avatar
the law
1. On a lot of cars in this area, but mainly Dodge/Chrysler minivans and Subarus, they have something on their front wheels called a "Spike's Spider". What is this thing? I havn't had the opportunity to ask one of the owners, so I'm asking you folks.
2. On probably half of the local cop cars, of both Ford and Chevy variety, and a few civilian cars, their is this 'strap' that hangs down. It is about an inch or so wide and just drags on the ground. I'm wondering what this is too. At first I thought it was just people letting their vehicles fall into disrepair, but I find it unlikely that the police would let that happen.
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56
Almost Stock
Old Aug 19, 2002 | 11:36 PM
Mil1ion's Avatar
Mil1ion
# 2 is a static strap.
Used to eliminate static cling.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 19, 2002 | 11:40 PM
Rocking M's Avatar
Rocking M
I've seen cars with competition stereos that have had a strap hanging on the ground. Not sure what they are for though.
Old Aug 19, 2002 | 11:45 PM
reddevilf150's Avatar
reddevilf150
Not sure if this is true but.... About the static strip, I was told it was for people who have pacemakers (sp?). It is so the static doesn't get in the car and mess it up?? Who knows, I might have heard wrong!??!!!?????
Old Aug 20, 2002 | 06:54 AM
94van's Avatar
94van
[updated:LAST EDITED ON 20-Aug-02 AT 07:55 AM (EST)]Never heard of a "Spike's Spider". What does it look like?
Static discharge straps have been around since the 50's. They were originally installed to eliminate the static electric build up that would accumulate and Zap you when you grab the door handle.
In newer vehicles, it assists in eliminating noise and interference in some electronics, like 2 way radios, radar guns, and on-board video cameras in police cars.
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Old Aug 20, 2002 | 09:46 AM
jim henderson's Avatar
jim henderson
The spikes spider is probably a snow traction device. Many newer front drivers and I guess some rears, have this option. Basically it is kind of a hub that sits on the outside of the rim. Most of the year, that is all you see. When it snows you snap on the "spider" which kind of looks like a propeller with the ends bent. The bent ends fit over the tread of the tire and supply traction. I hear it is very easy and fast to take off and put on.
Jim Henderson
Old Aug 20, 2002 | 10:15 AM
mercuryblues's Avatar
mercuryblues
the strap is used to remove static electricity .It stops people from getting car sick. Most transit busses use then. they are attached behind the rear axle so you can't see them.
Old Aug 20, 2002 | 12:07 PM
jberylecrider's Avatar
jberylecrider
Old Aug 20, 2002 | 02:42 PM
hitecdan's Avatar
hitecdan
>Jim Henderson
I'll second that, it is a snow traction device. Used on front wheel drive cars because they usually done have enough clearance between the wheel and fender well to handle a chain. The hub mounts onto the rim via the tires lug nuts. The traction device is usually a plastic composite of some type the snaps onto the hub when extra traction is needed.
Old Aug 20, 2002 | 07:37 PM
the law's Avatar
the law
Thanks folks, those things just got my curiosity rollin'.
About the static strap though, what does that do to the likelyhood of getting hit by lightning? Don't cars usually not get hit because they aren't grounded? Wouldn't this change that?
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56
Almost Stock
Old Aug 21, 2002 | 10:57 AM
TallPaul's Avatar
TallPaul
>change that?
Cars do get hit, but I have heard the occupants don't get hurt because the tires insulate the car from ground. Although I would think the strap would be better. You want the energy to flow to ground, not hold on the car, right? The car could build up a static charge by traveling through the air, the strap would dissipate the charge and I believe is on gasoline tankers to prevent static ignition when they stop to load/unload. Maybe we should put a sharp point on the antenna (like a lightning rod) to bleed off any static charge that otherwise would build up on our cars, thereby minimizing the chance they will attract lightning.
Peter94
36
Mar 8, 2007 11:26 PM
wolfmanagh
Aug 11, 2006 11:09 PM
FordRacing2
Aug 4, 2003 02:24 PM
88grandmarquis
Jul 11, 2003 04:21 PM
lastchance
29
Nov 14, 2001 04:26 PM
