Brake drum
Old Apr 14, 2017 | 05:20 PM
kalebc2's Avatar
kalebc2
Brake drum
I've tried everything to get the brake drum off it is locked up. Any other tips to get it freed up? Driver side rear brake drum
Old Apr 14, 2017 | 05:32 PM
Tedster9's Avatar
Tedster9
Make sure the brake adjusters are backed off. Heat works, a torch around the inner perimeter. Doesn't need to be cherry red A small sledge to break the rust bond.
Old Apr 14, 2017 | 05:55 PM
resonateur's Avatar
resonateur
1. Make sure your e-brake is completely disengaged
2. Back off the star adjuster from behind the backing plate...all the way loose
3. Penetrating oil around the wheel studs
4. Heat
5. Gentle tapping with a big rubber mallet while rotating the drum
6. Beg, borrow or steal a drum puller
Old Apr 14, 2017 | 06:41 PM
Blue and White's Avatar
Blue and White
All of the above. I once had a drum which would not budge with all the tricks. It had no lip for a puller (not Ford). I did not want to beat on it so hard I trashed the wheel bearings. Solution was to weld some lugs on the outside of the drum for a conventional (large) puller. With heat, tension on the puller and a sharp hammer rap it came free.
Goes without saying, new drums needed at that point. With anti-seize between drum and hub.
Old Apr 14, 2017 | 10:05 PM
PapaBearYuma's Avatar
PapaBearYuma
I haven't done this personally, but I've heard the technique used effectively...
Take out the inspection plug. Break out the gas torch. Release some gas into the inspection hole. Ignite the gas
Don't be in front of the drum when you ignite the gas.
Old Apr 14, 2017 | 10:19 PM
kalebc2's Avatar
kalebc2
Thanks I'll try it again tomorrow
Old Apr 15, 2017 | 10:06 AM
beartracks's Avatar
beartracks
Yeah Papa! Lets blow something up! I like your style.
Old Apr 15, 2017 | 11:03 AM
78 PEB's Avatar
78 PEB
Had a Bronco II years ago....drums didn't want to come off of it ..........heated and beat on them for a day.........borrowed some Aerokroil from a friend and sprayed them down real good.....let them sit till the next morning.......went to the shop and they came right off by hand.......If it wouldn't have happened to me personally, I wouldn't have believed it. I am not affiliated with Aerokroil.......just a very satisfied customer.....I haven't wasted my money on any other penetrating oil since (unless I am in a bind and don't have anything else).......that was damn near 30 years ago.......
pittmick
Oct 23, 2010 10:46 PM
AlaskanF150
Feb 19, 2005 06:00 PM
Saluki
Sep 13, 2004 12:56 AM
MAHinton
Jun 19, 2003 08:12 PM
bdonalds
Oct 30, 2001 10:13 AM
