351M or 400M
Old Apr 12, 2017 | 09:51 PM
JerryWieland's Avatar
JerryWieland
351M or 400M
What is a quick easy way to tell the difference between a 351M and 400M Ford engine? Also what is one of these engines worth that was running good when it was removed. Has an aluminum intake and Holley carburetor but the owner passed away and his estate doesn't know anything else about it.
Thanks Jerry
Old Apr 13, 2017 | 05:19 AM
PA74F250's Avatar
PA74F250
Check the stroke through the spark plug hole. Hard to say what they are worth really. Myself I wouldn't even pay for a 351M, a 400 I could see $300 or so for a unknown engine if it sounds good.
Old Apr 13, 2017 | 05:44 AM
JerryWieland
Well I can buy the engine for $150 and they will give me a transmission and transfer case off of it (or similar Ford) but I was hoping there was a quick way of figuring out what it was.
Jerry
Old Apr 13, 2017 | 07:00 AM
kegger66's Avatar
kegger66
I don't think it makes a difference in price whether its a 351m or a 400. If the engine block is NOT from the "bad period" than it's worth $300-500 easy. Especially if they throw in an C6 transmissions and transfer case.
Old Apr 13, 2017 | 09:53 AM
good to doo's Avatar
good to doo
Like what has already been said. To figure out the stroke pull all the plugs this will make it much easier to turn over with a breaker bar on the front(I,m sure someone will say its only nessasary to pull ! plug) Use a piece of wire and put it in the hole and roll the engine over. Then you can determine the stroke.
Old Apr 13, 2017 | 10:53 AM
gittinwidit's Avatar
gittinwidit
If it has the original valve cover on the driver's side, it was printed on a sticker that contains all the information. But valve cover could have been swapped easily...
Old Apr 13, 2017 | 11:45 AM
N2S3's Avatar
N2S3
What is the "bad period"?
Old Apr 13, 2017 | 12:06 PM
phlegm's Avatar
phlegm
Doesn't matter, for $150 you can't find an aluminum intake/carb anywhere else.
Buy it, figure the rest out later.
Old Apr 13, 2017 | 04:48 PM
JerryWieland
Yes I am going to buy the engine but I still want to know what the 'bad' period is?
....and thanks everyone for the information.
Jerry
Old Apr 13, 2017 | 04:53 PM
kegger66's Avatar
kegger66
Look here for the "bad" period
https://www.dropbox.com/s/uuou25fvt9...tion.docx?dl=0
Matt1966
Sep 1, 2016 05:20 PM
CalebJns
Mar 26, 2010 01:05 PM
trapperjack
41
Feb 14, 2010 11:24 PM
grumpy1
20
Nov 21, 2003 02:43 PM
justind
Jan 26, 2002 01:32 AM
