Pedal assembly removal
Old Apr 12, 2017 | 09:43 PM
Nathan Koeppe's Avatar
Nathan Koeppe
I'm trying to remove the pedal assembly off my 86 f150 for a tranny swap and I'm having trouble getting it out. I've removed the brake and clutch linkages to their master cylinders and took all the bolts and nuts off and it won't budge. I know aluminum can fuse to rusted steel and that's what it looks like happened on the 4 studs coming from the booster. Any ideas? Will I have to remove the booster? Thanks
Studs from brake booster holding going through the firewall
Old Apr 13, 2017 | 04:54 AM
Ken Blythen's Avatar
Ken Blythen
A few years ago I swapped from auto to manual in my truck & I pushed the booster forward so the studs were back through the firewall & out of the way; but I didn't disconnect any of the hydraulic lines.
It's not the easiest job physically to remove/install that bracket (don't hit it.....they're brittle )
By the time I had swapped it, then connected the clutch linkages, swapped out the shift indicator & reinstalled the steering column, plus cut the trans access hole in the floor.......I think I spent at least as much time working in the cab, as I spent under the truck with the bell housing, clutch, trans & driveshaft.
Old Apr 13, 2017 | 06:02 AM
Franklin2's Avatar
Franklin2
You need to get under the hood and grab the booster/master cylinder and pull them forward. You can leave the lines connected, just be careful. The pedal assembly needs to slide down from under the dash, no way that is going to happen with those studs in the way and the brake rod in the way.
Old Apr 13, 2017 | 07:08 AM
Nathan Koeppe
I'm in the final stages, so I can see the light at the end of the tunnel. Thanks
Old Apr 13, 2017 | 07:09 AM
Nathan Koeppe
that's stuck pretty good as well. Last night I soaked them in wd 40 and went inside so hopefully I'll have luck today. Thanks
Old Apr 13, 2017 | 08:04 AM
reamer's Avatar
reamer
the light at the end of the tunnel is usually a train.....
Old Apr 14, 2017 | 01:39 PM
grumpin's Avatar
grumpin
Old Apr 14, 2017 | 07:16 PM
Eddiec1564's Avatar
Eddiec1564
I can't tell from your photo, but did you get the two bolts out thats on the top of the bracket?
My 84 F250 without the dash, its the top firewall mount bracket.
hfd315
27
Oct 21, 2017 07:30 PM
1978f250cummins
Sep 19, 2016 07:21 AM
Ford_Guy123
Feb 15, 2016 08:03 AM
CountryBumkin
Sep 22, 2013 02:08 PM
kjb63
1978 - 1996 Big Bronco
Jan 5, 2003 04:03 PM
