Bed bolt removal
Old Apr 12, 2017 | 08:46 PM
jacobn936's Avatar
jacobn936
Question Bed bolt removal
Does anyone have a good way to remove the floor bolts from a flareside? Trying to re-do my bed and all the bolts in the wooden floor just spin.
Old Apr 12, 2017 | 09:39 PM
skidoorulz's Avatar
skidoorulz
Grab the head with a pair of vise grips and use an impact on the nuts below while someone is holding the vise grips. If that don't work use a hot wrench
Old Apr 13, 2017 | 09:27 AM
tinman52's Avatar
tinman52
Welder User
Normally I tack weld the heads to the bed, then cut them free when the nuts are off. In your case you could weld on a longer piece of metal that would wedge against the bed side.
Old Apr 13, 2017 | 10:46 AM
resonateur's Avatar
resonateur
...or grind the heads off and punch 'em down through. That way you're doing all your work from above...no dirt in your face. We're a destructive bunch 'eh?
Old Apr 13, 2017 | 10:56 AM
gittinwidit's Avatar
gittinwidit
I would weld a large nut on top to hold it in place. That would not affect any of the bed for restoration.
Old Apr 13, 2017 | 08:32 PM
jacobn936's Avatar
jacobn936
I like the idea of welding a nut on top. May try that. Thanks, guys.
Old Apr 15, 2017 | 06:42 AM
shipwrecked's Avatar
shipwrecked
Every bolt on my bed was rusted together.
I took a grinder with cut off wheel and slotted the head of the carriage bolt.
Then clipped some needle nose vise grip onto the slot heat and a big F'n breaker bar on the nut.
Old Apr 16, 2017 | 07:33 PM
jacobn936's Avatar
jacobn936
shipwrecked, I did this. Only difference is I used an impact on the nuts. Worked like a champ. Thanks for the idea.
Built_Ford_Tough_757
Feb 25, 2015 06:15 PM
Eallend7
29
Mar 10, 2013 11:29 PM
Epd444
Jun 5, 2011 09:03 PM
IowanStraight6
Dec 1, 2009 01:17 PM
DJdemon6696
May 24, 2009 06:51 PM
