Does grind off heads of bed bolts free bed?
The title says it all would grinding off the heads of the bed bolt and hammering them through work on 94 i guess last resort load truck up on cartrailer and bring to cousin to have them welded to bed or the nut theiorey i just feel to lazy to winch it up with a comealong.
I ground the dome-heads off the bolts in my '97 to remove the bed. I had to punch them through the bottom hole with a drift pin but the bed definitely came off.
I tried removing the nuts first and by spinning them turned the square hole round. Gave the bolt a bit more room to drop down. But, grind the head off as completely as possible.
And another thing - don't put your hand down onto the head of a bolt you have just been grinding on.....it hurts and leaves a perfectly round blister.
85'blackedout
11-08-2010 06:02 PM
