Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
67 f600 decode help??
Old Apr 12, 2017 | 03:23 PM
bleedbluetrucknut's Avatar
bleedbluetrucknut
Wondering if anyone had a website to decode the vin and data plates on these old trucks, cant seem to find much info online...
vin. F60dkb26794
Color. J
model. F602
body. 481
trans. A
axle. F8C
weight. 20k
net H.P. 164
rpm. 7800
DSO. 55
Old Apr 13, 2017 | 11:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bleedbluetrucknut
VIN: F60DKB26794 / WB: / COLOR: J / MODEL: F602 / BODY: 481 / TRANS: A / AXLE: F8C / MAX GVW LBS: 20000 / CERT NET HP: 164 / RPM: 3800 / DSO: 55
F60 = F600 (gas).
D = 330 2V H/D FT engine.
K = Kansas City MO Assembly Plant.
B26794 = 1967.
Wheelbase (omitted).
J = Rangoon Red.
F602 = F600 (gas) .. 20,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Bar Pattern Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F8C:
F8 = Eaton model 13802 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
C = Ford Rockwell-Timken 6,000 lbs. Capacity Front Axle.
20,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
55 = St. Louis MO Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Apr 13, 2017 | 01:15 PM
bleedbluetrucknut
Thanks
Awesome, thanks is there a website you are getting this info from?
looks like it never made it out of missouri, 100 miles from where it was ordered, 200ish from where it was built.
Old Apr 13, 2017 | 02:47 PM
NumberDummy
Nope, a Ford truck parts catalog.
Looks like it never made it out of missouri, 100 miles from where it was ordered, 200ish from where it was built.
I assume you're referring to the VIN/Warranty Plate decode I did in your other thread.*
Info came from the 1964/72 Ford Truck Parts Catalog, available on a C/D from hipoparts.com
*threads merged by moderator
EMH_metals
Large Truck
Oct 6, 2020 03:35 PM
TaylorDiabetoSwifty
Large Truck
Mar 20, 2017 12:51 PM
Snowmanii
Large Truck
Oct 23, 2016 11:17 AM
coyote1442
Large Truck
May 20, 2015 05:24 AM
wiesman2613
19
Mar 14, 2015 08:11 PM
