Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C700 vin decode.
Old Oct 21, 2016 | 02:14 PM
Snowmanii's Avatar
Snowmanii
C700 vin decode.
Need help with vin plate.
Warranty # c759u625936, WB 175, color L, model c752, body 191A, trans P, Axle H8, max gvw lbs 25500, cert 19 9, net hp 380, RPM 0 (Q?), dso 55.
Thanks
Old Oct 22, 2016 | 01:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Snowmanii
Need help with Warranty Plate.
Warranty # C759U625936 / WB: 175 / COLOR: L / MODEL: C752 / BODY: 191A / TRANS: P / AXLE: H8 / MAX GVW LBS: 25500 / CERT NET HP: 199 / RPM: 3800 / DSO: 55
C75 = C700 Tilt Cab (gas).
9 = 391 4V
U = Louisville KY Assembly Plant.
625936 = 1965, assembled November 1964.
175" Wheelbase.
L = Holly Green.
C752 = C700 .. 25,500lbs. GVWR
191A: 1 = Light Gray Crush Vinyl & Light Gray Block Weave Vinyl / 91A Standard Cab.
P = Dana/Spicer model 5756-B 5 Speed Direct.
H8 = Eaton model 17801 Two Speed Rear Axle / 7.17/9.77 / 18,500 lbs. Rear Axle Capacity.
25,500 lbs. Gross Vehicle Weight Rating.
199 net HP @ 3,800 RPM
St. Louis MO Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Oct 23, 2016 | 11:17 AM
Snowmanii's Avatar
Snowmanii
Thanks so much Bill!
EMH_metals
Large Truck
Oct 6, 2020 03:35 PM
bleedbluetrucknut
Large Truck
Apr 13, 2017 02:47 PM
Oldtrucklover80
Large Truck
Oct 8, 2016 11:55 AM
MarkB65
Large Truck
Aug 11, 2016 09:44 AM
Merty
Large Truck
Jan 29, 2015 06:51 PM
