Can I swap my 18” rims with 20” rims without changing axle gear ratio = “2017” 3.5L V6 Ecoboost W/Auto S/S 10-Speed Auto W/Tow MO - 3.31 Electronic Lock RR Axle
Might want to post on the 2017 F150 section; you will likely get answers there a lot faster. Or ask the Mod's to move this thread to the proper place. Good luck.
That shows a pretty small difference in the tires. Assuming those are the tire sizes you are looking at you wouldn't even need to re-calibrate the speedometer or change the gears.
A new F-150 can be had with either of those rims, and 17" as well. The difference is in the tire profile and circumference (or diameter if you prefer). Put the correct tires on, and there is no difference in the end result.
DLEWIS1624, i saw You say "without changing axle gear ratio". I am new to this and would like to know what i have to do in order to change my truck's axle gear ratio?
Any explanations would be fine to noobie
Richard
Richard
Have the ring an pinion gear changed in the axle. Both front and rear if it is four wheel drive.
