1955 F-250 Rear axle ratio
I have a 55 f-250 with the 4 speed synchro transmission and a 4.88 rear axle ratio. I am going to use my truck as a daily driver and to sometimes haul/tow small loads. Is this ratio to extreme for a daily driver and if so what should i change it to? I also heard that it is easier to just change out the entire axle.
First, 1955 F-250s didn't have two parts wheels. They had/have the same 16" x 6" one piece "innie" wheels first used on F-2s in 1948. They are K-H 31282 / Ford 7RD 1015-B. The stock tire sizes were either 6.50-16" or 7.00-16" which explains your 28" figure. The 6" wide rim will easily accommodate a 7.50-16" or comparable radial in 235/85R16" size that both measure about 32" tall. That alone would help road speed without hurting towing ability.
There were two rear axles used in 1955 F-250s. Either a split case Timken A150 having a 4.86/1 ratio, or the Dana/Spicer 60 having the 4.88/1 gear set. To achieve a lower final drive, perhaps a 3.54/1 or 3.73/1, you'd be looking at swapping for a later Dana 60 out of a 1972 or earlier F-250. Ideal years I believe I've read are 1967 to 1971 which are essentially bolt in swaps without other needed modifications. Stu
nash22
10-12-2011 07:58 PM
icobod
16
09-21-2011 05:40 PM
