1st Oil change with Filtermags on
Old 08-19-2017, 05:36 PM
willydmax's Avatar
willydmax
willydmax is offline
Overkill, I'm sure curious what you'll find when cutting it open. I personally think you will be able to see an outline of every magnet from inside the filter by the metal stuck on it.
  #62
Old 08-19-2017, 10:12 PM
Overkill2's Avatar
Overkill2
Overkill2 is online now
Making donuts deplorable
Received 6,476 Likes on 4,712 Posts
I could just cut it open and post the pics but I don't want to be accused of doctoring anything so I want to video the opening so everyone can see what I see when it's opened up and cleaned. I have never posted video before so be patient...I will get it done. There's a lot of stuff going on now and I am a master procrastinator...I have a YouTube account and maybe I'll post it there...
  #63
Old 08-22-2017, 03:37 PM
Dakster's Avatar
Dakster
Dakster is offline
Thanks for sharing what you are doing Overkill - Internet is a rough place. You can't say you had a good experience with something and not have people attack it.
I do remember when even the OEMs put magnets on the end of oil drain pan plugs and when the oil was changed they always seemed to have gunk on them.
If this makes anyone feel better, like adding extra fuel filters, then great. Go for it. This isn't a huge expense and could get moved to another vehicle easily, so this isn't as much as investment as other products.
Stay safe out there.
  #64
Old 09-06-2017, 09:00 PM
Overkill2's Avatar
Overkill2
Sorry for late reply Dakster...I just saw this tonight. I appreciate the thumbs up. Yeah I hear ya...I guess I just wanted to really try to get across how they work...and maybe I got a little defensive...my fault. Maybe when I change my oil, I'll video record how hard they slap onto the face of the filter. Appreciate the well wishes, my friend. Once I do some more of the stuff I want to add to the truck, people will see why my handle has the word overkill in it...
  #65
Old 03-15-2018, 12:50 PM
FMJ.'s Avatar
FMJ.
FMJ. is offline
@ Overkill2,
Thank you for taking the time and effort to do your 1st post.
I just came across it by chance while doing some google homework.
I've used a powerful speaker magnet on the oil sump for several years, and I know of some local drag racers that use a handful of small magnets on their oil filters.
I did not know about the filtermags until now. That's actually what I want, and what I've just ordered.
I've also recently come across the following :
EZ-115 : NPT 1/4-18 | EZ Oil Drain Valve
These are brilliant to replace the block and radiator drain plugs, as well as tranny and oil sump plugs.
I fitted them and tested them. No leaks, and no annoying mess when draining.
The picture below shows their size with the marlboro box to help with perspective.
Laterz.
  #66
Old 03-16-2018, 07:01 PM
Overkill2's Avatar
Overkill2
Originally Posted by FMJ.
@ Overkill2,
EZ-115 : NPT 1/4-18 EZ Oil Drain Valve
Laterz.
No worries, FMJ. I procrastinate some but still want to make a video to post up and cut open the used Motorcraft filter that I have with the Filter Mags still on . I have a second set that I am using now.
Yes, I have seen the oil pan drain valves before and most of the guys here use these:
For Ford 2016 F-350 Super Duty 6.7L V8 Turbo Diesel
  #67
Old 03-17-2018, 01:07 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
Received 1,023 Likes on 784 Posts
Originally Posted by djousma
The amount of metal in your filter is concerning. Not sure what good the magnets do, as that metal would be trapped in the filter anyway.
ditto
either wrong oil wieght for weather conditions, too much time on the oil (maybe use severe duty schedule instead) or the oil does not have enough zinc, phousperous, boron
its cool that the magnets catch it, but whats cuasing it
  #68
Old 03-18-2018, 09:19 AM
Overkill2's Avatar
Overkill2
Hey *****, sorry for late reply...WAY LATE. If you didn't go to 1st page of thread, there are pictures which show the outline of each magnet.
  #69
Old 03-18-2018, 09:25 AM
Overkill2's Avatar
Overkill2
Originally Posted by speakerfritz
ditto
The pictures were taken at my first oil change at 5000 miles, give or take. It was factory fill so I'll assume it was Motorcraft Super Duty 10w30. I still use Motorcraft Super Duty 10w30. Since it was the first oil change on a brand new truck, I'm sure those are particles from the engine breaking in.
I'm at about 21,500 miles currently and the truck runs like a raped ape. If I have any catastrophic failure** of my engine, I'll let you guys know.
**Man, I hope I didn't jinx myself as I just read Lar man's thread about his 16 6.7 Powerstroke.
frenchy750
12-20-2010 06:20 PM
wla6518
13
05-02-2010 05:42 AM
bigbadwolfe
03-18-2007 09:19 PM
rsylvstr
Modular V8 (4.6L, 5.4L)
01-12-2007 09:47 AM
stiffysteele
39
02-10-2004 06:05 PM
Quick Reply: 1st Oil change with Filtermags on
