Sponsored by: Real Truck
A/C electrical problem
Old Apr 11, 2017 | 11:47 AM
ChattanoogaJack's Avatar
ChattanoogaJack
1999 7.3 Powerstroke
I've got an electrical problem. I have put power to the clutch and that pulls in. The fuse is good, if in fact #24 as I've seen here. With only 4 wires in the system, a panel switch, the clutch solenoid, and the pressure sensor, would seem simple enough. But panel switch is tough to get to. With ignition on and panel switch on, I would think I would get power to either the red w/ white stripe to sensor or white wire going to clutch, but I don't. So I figure the sensor is in line somewhere but seems to be normally closed, so I would think power thru the sensor would go straight to clutch. Where does the red w/ white stripe come from, that goes to sensor? That's got to be the hot because the black at clutch goes to ground.
Obviously no manual here. Just looking what to check next. Thanks
Old Apr 11, 2017 | 01:19 PM
alloro's Avatar
alloro
Just for the heck of it, check fuses 22 and 23 also since those power the blower circuits.
Here is the wiring diagram for a 99.
File Type: pdf
Old Apr 11, 2017 | 01:33 PM
projectSHO89's Avatar
projectSHO89
F22 and F23 will have no effect on the operation of the compressor clutch. The clutch is directly powered by the simple series circuit of F24 > Mode Switch > Cycling Switch > HPCO switch, and the coil to ground.
All one has to do is successively half-split the circuit, checking for voltage (key in RUN, mode switch not in OFF, VENT or FLOOR) and see where the voltage is lost. See page 2 of the diagram alloro posted.
Golden1991
31
May 30, 2018 08:04 AM
TimmyAbrams
1978 - 1996 Big Bronco
Sep 6, 2007 04:58 AM
johnsdiesel
29
Oct 26, 2005 04:57 PM
aerotexas93
Aerostar
Dec 1, 2003 04:43 AM
cmosis5
Feb 2, 2002 12:49 AM
