292 Mileage Issue
I'm pretty mechanically inclined, but I haven't messed around with older trucks much, let alone carburetors.
I just bought a 64 F100, with 292 (Autolight 1100) and 4 speed granny low. The last owner said it was getting 10-12 mpg, and my limited time driving seems to agree.
I've read that around 16mpg is "normal", and the last owner said it was running rich. I don't have a baseline, but it seems to be idling high too.
All in all, the truck runs well, no surging. It seems to live at 45mpg, screams at 50, but I think that's just the gearing. Sometimes get bogged down on Cali hills, but I need to replicate that. I have smelled gas when driving, but when I stop and check, it's not leaking fuel.
My plan for this weekend is to change the plugs, let it idle for 20 minutes, pull the new plugs, and read them. If it is running rich, I think I'll need to adjust either the idle mixture valve, or change jets. I'm not sure which. What jets should be used? How do I set idle mixture?
Anything else I can/should try?
Thanks for your help guys
-L
) and Warner T-98 4 speed granny low. The last owner said it was getting 10-12 mpg, and my limited time driving seems to agree.I've read that around 16mpg is "normal", and the last owner said it was running rich. I don't have a baseline, but it seems to be idling high too.
These trucks have the aerodynamics of a brick, city MPG was 10-12, don't expect to get much better. Highway MPG could be 13-16, if you drive no more than 55 MPH
When new, a gallon of regular gas was around 25 cents...and NO one back then gave a hoot about MPG!
The motor is not screaming at 50mph - that should be in the neighborhood of 2500rpm. If it is loud, it is the exhaust, maybe a louder than stock muffler, or simply a worn out exhaust system.
Get a tachometer to check the rpm so you are not making assumptions. There are tools to do that, if you do not want to have one installed permanently.
If it is idling rich, you adjust the idle mixture. If it is rich while driving and cruising, which is above idle, then you change jets.
No one can tell you which jets should be used. Use what is installed and adjust, if necessary, until it is right.
Since you just got it, a thorough tune up should be done. If the distributor is original, it needs a rebuild, probably the same for the carburetor.
Get a shop manual. They are available as reprints, or on CD. It will have answers to many of the questions you will have and then you don't have to wait 15 minutes, hours, or days for a reply on a forum
Can you guys clue me in on how these guys are getting such high numbers? Are their motors not stock?
https://www.ford-trucks.com/forums/1174219-292-mpg.html
All of the information needed is online, you'll just have to dig for it. What my dad used to call "effective use of source material."
The first thing you want is the Ford Shop manual for 1964. There, you'll find ALL the specifications and such for your truck and engine. Tune-up and troubleshooting. It will tell you to perform a cylinder compression test. This will indicate the general overall health of the pistons and rings and valves. The reason to do this before getting spooled up about anything else, if the engine is clapped out, it needs an overhaul. If it's in good shape, then you can proceed from there.
John
That said, a lot of people like to make their old vehicles more fun to drive and many of the things you do to increase performance will also increase fuel efficiency. There is a limit, of course, for instance, you don't put a drag race cam in a street engine and get better mileage, but a step or two up from a stock cam, maybe even a little bigger, should give you a nice boost in power and efficiency, when everything is tuned correctly. A compression increase will help both power and efficiency.
Another thing to consider is that many of these old vehicles need transmission work. Many times, the cost to upgrade to overdrive is not that much more expensive.
So you can get it without focusing on it, or as a side effect of another necessary repair but however it happens, don't kid yourself into believing that you are actually going to save money on it. Odds are you won't.
The best game plan is to make sure what you have is working correctly and tuned properly. When I say tuned properly, I don't mean by the book. I mean that you take the time to actually tune it and make it the best it can be.
