Won't start again, need help
Old Apr 10, 2017 | 11:41 PM
1984_IH6.9_Project's Avatar
1984_IH6.9_Project
Hi, I'm working on rebuilding my 84 F-250 and I'm currently working on the body but I've been trying to start it so it doesn't just sit and not run for these months. It was starting fine after I replaced the glow plugs and controller last time, but after setting for about a month and a half I got my ignition actuator replaced and the column back together and it wouldn't start until I wired in a push button for the glow plugs. It's been setting for 2-3 weeks because I can't get it to start now I've checked the things I know. Glow plugs are getting power, glow plugs are working, and it's getting fuel the only thing I know is bad is the vacuum pump. It cranks hard and tries to start but it doesn't start. I'm unsure of trying the block heater since I have the 84 block. Some extra information; it set for 7-8 years before I got it, I've replaced the glow plugs twice since I got it in 2015, one wire broke and I had to splice it to get it to start, key stopped starting it so I was jumping the solenoid for 2 month to start it, glow plugs had to be cycled 20-30 times before it would start before I put in the push button, eather doesn't help it start at all, it has a small oil leak but it just leaks outside the block and I keep it full of oil, and I'm only holding the glow plug button for 8 seconds. I can't think of why it won't start so I figured I would ask here since I'm still kinda new to IDIs and you guys probably have a better idea of what it could be than I do.
thanks for any help
Old Apr 11, 2017 | 11:17 AM
Dieselamour's Avatar
Dieselamour
"...and it's getting fuel..." Are you getting fuel at the inlet of the IP or all of your injectors?
Old Apr 11, 2017 | 03:28 PM
1984_IH6.9_Project
all the injectors
klle5
Dec 25, 2015 11:06 PM
91 7three
Apr 28, 2015 09:51 AM
90pioneer
Nov 5, 2011 09:09 PM
hedhntr
Aug 31, 2010 10:51 PM
AndysFords
Aug 22, 2009 09:52 PM
