new truck issues update
Old Apr 10, 2017 | 06:27 PM
ever22's Avatar
ever22
Hey Yall, as previously posted, have had couple issues on 350 S/D C/C delivered on 12-28. First issue was no interior lights, traced to pinched wire in harness, problem repaired by dealer. Second issue, intermittent starter grind issue, dealer unable to replicate, hasn"nt happened recently, hope it doesn"t happen again. Today stopped by carwash to rinse off truck, as I left noticed water dripping out of upfitter switches, GRRREAT. Dealer notified, will post what happens next. I have clearance lights, assume thats where leak is occurring. Anyone else had this problem? Thanks.
Old Apr 10, 2017 | 06:35 PM
Super-Truck's Avatar
Super-Truck
Sorry to hear, hopefully it works out to your advantage. I have both the moonroof and clearance lights and have not had an issue from either. Ive been to the car wash and have had some very serious rain, still not a drop inside.
Old Apr 10, 2017 | 06:59 PM
EpicCowlick's Avatar
EpicCowlick
I've had the starter miss three different times since October. I've logged each time and will continue until I get to end of warranty. Not much else you can do until something breaks.
Old Apr 10, 2017 | 07:07 PM
natpark's Avatar
natpark
I have had one starter miss in 7000 miles so far. Keeping an eye on it as well.
Old Apr 10, 2017 | 07:11 PM
senix's Avatar
senix
check the sunroof in the corners for block drain tubes.
Old Apr 10, 2017 | 08:35 PM
ever22's Avatar
ever22
Have no sun/moon roof, thats why I assume it"s clearance light that"s leaking. Starter grind issue has probably happened 30 times in 3000 miles.
Old Apr 10, 2017 | 09:08 PM
HRTKD's Avatar
HRTKD
There is a thread around here where the owner said that it looked like the clearance lights weren't sealed to the roof. Or something like that. Makes me glad I didn't get that option. Sorry to hear yours is leaking.
Old Apr 10, 2017 | 09:10 PM
Melansk's Avatar
Melansk
I have had the same issue leaking through the up lifter switches. The water was coming through the satellite/gps antennae on the roof on the passenger side. dealer repaired by putting new one in.
Old Apr 17, 2017 | 08:02 PM
ever22's Avatar
ever22
New truck issues
For anyone interested, had truck back to dealer today, they brought in an outside company called "seek and seal". Apparently they specialize in air and water leaks, they determined water was leaking around clearance lights on roof, and resealed them. Am hoping they got it taken care of, will post again if any other issues arise.
Old Apr 17, 2017 | 08:51 PM
rezneck's Avatar
rezneck
My clearance lights had moisture in two of them when I picked up the truck a few weeks ago, they ordered new ones right away and I'm bringing it in sometime this week, they are replacing all of them and not just the two that had moisture in them. I did look at them and they don't seem to be sealed all that well where the join at the roof, there is a gap between the light and roof. Haven't had any water leak in but if left any longer I would assume they would at some point. Hopefully the the dealer seals them better than how it came from the factory!
loudoun
17
Jan 12, 2015 12:49 PM
dylansf23
Nov 17, 2013 01:09 AM
Steverinosoftball
Dec 23, 2011 07:27 PM
imlowr2
16
Jun 15, 2006 01:02 PM
BroncJMU
1978 - 1996 Big Bronco
Aug 31, 2004 10:08 AM
