Battery smoking
Old Apr 10, 2017 | 01:55 AM
Treeguy604's Avatar
Treeguy604
Battery smoking
So today I am driving it was a pretty long drive and I noticed one headlight was out so I went into Walmart get the new bulbs and I look and smell my battery boiling from the drive I didn't run her hard well to hard those canyon hills are stupid but she was smoking and it sounded like she was going to blow up but I took my time and managed to limp her home can anyone shed some light in this as I am brand new to idi and mechanic work as o am a tree guy
Old Apr 10, 2017 | 02:43 AM
genscripter's Avatar
genscripter
How do you know your battery was boiling? I've never heard of that.
Old Apr 10, 2017 | 07:33 AM
Treeguy604's Avatar
Treeguy604
It was getting really hot and the smell of rotten eggs the sulphur and you could see it steaming really bad and getting so dann hot that it was kind ****ed up had to limp my truck home
Old Apr 10, 2017 | 10:11 AM
tecgod13's Avatar
tecgod13
Check the liquid level inside the battery. It could be very low.
Also check the alternator output. If you are overcharging the batteries that can overheat them and cook them pretty fast.
This is also incredibly dangerous. You really don't want a battery to explode in your face!!!!
Old Apr 10, 2017 | 10:17 AM
bla1879's Avatar
bla1879
check the water level in the battery, its probably low.
Old Apr 10, 2017 | 12:02 PM
madpogue's Avatar
madpogue
Which battery?
Old Apr 10, 2017 | 03:28 PM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like there is an issue with the voltage regulator and the battery is overcharging.
Old Apr 10, 2017 | 04:02 PM
genscripter
It's hard to tell, cuz the OP doesn't have a sig or any information. But I concur.
Old Apr 10, 2017 | 04:08 PM
madpogue's Avatar
madpogue
Why would it overcharge only one battery?
Old Apr 10, 2017 | 10:02 PM
Macrobb's Avatar
Macrobb
If one(or two) of the cells in the battery short out, now you've got 14V across 4-5 cells. This /will/ produce heat, boiling and hydrogen sulfide gas.
Old Apr 10, 2017 | 10:13 PM
eagleye's Avatar
eagleye
disconnect the suspect battery and measure the voltage cold after filling with distilled water, if low. it should be 12.2 to 12.8 volts. If it's low connect to a slow charger 2-3 amps. If it doesn't charge the battery is bad and you have shorted cells that caused the boiling. THat can be a very dangerous and potentially explosive.
First check alternator / regulator output voltage when running that can overcharge the battery and kill it. even if one battery is still good. The question is also is this an older model with a separate regulator or is the regulator built into the alternator.
You mentioned a light was out? Could there have been a short causing a problem with the light out and the battery boiling? check the wires around the battery and headlight?
Old Apr 12, 2017 | 05:52 PM
hturner12's Avatar
hturner12
Electrical components are not normal smoke producers, when they do the do not function afterwards
Old Apr 12, 2017 | 07:00 PM
Tedster9's Avatar
Tedster9
If they are badly mismatched. Electrically they are connected so to make a single larger battery. One may be hogging all the current.
Old Apr 13, 2017 | 10:16 PM
eagleye's Avatar
eagleye
If there is a bad cell, then that will hog all the juice and the good battery will never charge. eventually, that dead cell can kill a good battery connected to it since the bad battery will pull the voltage down from the good battery.
The solution is pull both batteries and individually trickle charge them. Once done and resting several hours, check the voltage on both batteries. they should be the same. If they are .2 volts apart or more then they are not matched. THey should both read around 12.8 Volts.
Old Apr 14, 2017 | 12:02 AM
Treeguy604's Avatar
Treeguy604
Yes yes it was a dead battery I replaced both and things are good not sure if I mentioned it or not but I also put new belt cause it's old and was slipppng on the power steering the truck is running good I still have a glow plug issue but it is warm out sucks I have to plug it in but that comes in two or so weeks and it's my weekend truck so it works
Klemhineycutt
Jan 9, 2019 08:25 PM
omni
Electrical Systems/Wiring
Nov 18, 2014 05:28 PM
aurgathor
Jan 29, 2005 12:50 PM
Munkey
Aug 16, 2004 11:29 AM
76Econoline
Oct 3, 2003 06:29 PM
