Trim Protection
Old Apr 9, 2017 | 07:07 PM
72CC428's Avatar
72CC428
Trim Protection
I have a 72 F250. I stripped all the trim and wet sanded it down to 1500 and then polished with Mothers. It shines like chrome. What is the best thing to do to coat it? Should I take it somewhere and have it clear coated or????/
Old Apr 9, 2017 | 09:28 PM
Beechkid's Avatar
Beechkid
clear powdercoating would IMHO be the best but you could also spray it with clear urethane (next best)
Old Apr 9, 2017 | 09:53 PM
mrpotatohead's Avatar
mrpotatohead
How did you strip it?
Old Apr 9, 2017 | 10:14 PM
72CC428's Avatar
72CC428
150 GRIT on an adjustable speed orbital sander. I tried the oven cleaner trick but you need to baby sit each piece or else you'll end up destroying it. I almost ruined one piece so I went to sanding.
If it is something you are thinking about doing, first, think real hard. Very labor intensive. I went from 150-220-240 on the orbital ( 240 was a waste ), then 320 wet- 500 or 600 wet ( depending on what I had ) to 800-1200-1500 wet then Mothers aluminum polish x3 with the polishing wheel on my variable speed drill and then one more pass with the buffing pad on my buffer. Came out looking better than chrome really. That's why I want it coated.
I don't think I can powder coat because I used pin stripe tape for the black lines. Guess I would have to ask the guys who powder coat.
Here's a couple of pics...
This is basically a pic of the stages before the polishing
Grill after polishing
This was on the cloudy day
Old Apr 10, 2017 | 10:15 AM
mrpotatohead
Nice work.
Old Apr 21, 2017 | 09:24 PM
72CC428's Avatar
72CC428
Urethane or polyurethane??
Also, how should I prep it prior to spraying it. I will be using rattle cans.
Thank you, Todd.
Old Apr 22, 2017 | 08:42 AM
Beechkid's Avatar
Beechkid
IMHO, poly is typically used for wood where Urethane is a typical automotive type product, but with that said, there are numerous options on the market......IMHO, I would visit the local autobody paint supply store, they can mix you up a product & put it in a spray can or IMHO the best of this, would be to visit a local auto body shop and with the component in hand, ask them how much to spray it..........
Old Apr 23, 2017 | 10:01 PM
72CC428's Avatar
72CC428
That's what I am leaning towards,
Old May 29, 2018 | 08:37 AM
bajafishnut's Avatar
bajafishnut
I believe Beechkid to be correct in his information. Poly is used for wood mostly. I just went back over several pages of your build, and concur, nice work amigo. You are proceeding at the "Speed of Right", and you cannot go wrong with that approach..
Baja
FoPar1972
Aug 1, 2023 07:43 PM
caravaggio2000
Jul 24, 2019 10:31 AM
MCDavis
2004 - 2008 F150
17
Mar 25, 2012 07:57 PM
berry1234
Aug 10, 2010 01:04 PM
2bocat
Paint & Bodywork
Aug 18, 2005 10:00 AM
