Best method to repair bent fender
With dents the way to pull them out is just the reverse of how they went in.
The tire tread rolled the lip under.
You can try heat but be careful not to use too much and warp it.
I am not for heat.
I would remove the old brace, might be able to save it?
Grab the panel and roll it back out by pulling it down & out at the same time.
You may also need to hold your hand on the outside just above the bend wile you roll the panel back out.
May also need to do a little hammer work wile rolling the panel back out. Use body hammer as it has a large flat head and a paint stick on the area to be hit.
This is where a helping hand comes in handy. The paint stick should spread the blows out more and keep from scratching the paint.
Go easy is all I can say.
Dave ----
ps: yes I have done body work for a living
I am not for heat.
Dave ----
gdub
09-06-2011 10:31 AM
