Amazing what a little chrome polish will do..
Noticed the headliner trim was getting pitted and spotty and thought I would need to re-chrome it. I tried some Turtle Wax chrome polish and 30 minutes later it looks great. There is some small pin size spots I couldn't get, but huge improvement. Thought I would share.
Before.
After
Before.
After
Just those yellow micro fiber rags from Costco. Any micro fiber will do. A lot of pressure and try not to rub the surrounding paint/headliner. I did each section about 3 times with a new spot on the rag and fresh drop of polish.
The only option for cloudy/dull anodized aluminum is to strip the anodizing, polish then leave it or get it anodized again. It's a lot of work.
I stripped the coating off my grille shell with oven cleaner, sanded for what seemd like forever, 400, 600, 800, 1500 then polished with buffing wheel and by hand. Looks good, but nothing like a new shell from DC or chromed shell from LMC.
It wouldn't work at all on the outside trim, because of the anodizing. You'd need to lift the anodizing, polish the aluminum and then refinish. If you use any form of polish on your outside trim, it'll look a tad better for about 30 seconds, then go back to being just as cloudy as before.
To the OP...looks really good. Amazing what a little time and elbow grease can do, huh?
on
i just read that you can also clean up chrome with a piece of balled up tin foil and one of three different products (all work):
1) Tin foil + Coke
2) Tin Foil + Vinegar
3 Tin Foil + Water
Be aware of what you're doing though. After you're done taking off all that rust, make sure to wax/polish it down so that you can keep it as nice as it is once it's cleaned.
The first two methods were proven by a user whom posted on the Paint/Autobody Forum.
Try it! I know I am.
1) Tin foil + Coke
3 Tin Foil + Water
