I need to order some lug nuts to mount the adapter to my truck . I am just trying to make sure I found the correct lug nuts on Amazon . I found some open end bulge acorn wheel lug nuts 14x1.5 hex size 19mm in the title but in lower description it says 22mm ? They are sold in a set of 12 by Best For Auto .I obviously need 32 nuts but I am trying to figure out if these are the lug nuts I need to mount the hub centric adapters . I have the outer lugs to mount the rims already .
The truck is a 2016 F350 dually FX4 Lariat . Thanks for any help !
Thanks it probably is the 22mm it just probably a mistake in the title on Amazon. The 8 to 10 lug adapters use the acorn nuts to hold the steel adapters , they are lug and hub centering both .
I am waiting for a answer from the website that seville009 sent me the other day to just make sure since they sell adapters also so I can buy them from them also! Thanks for the answers!
These are going on adapters? If so, I'd get the smallest hex available. 21mm or 19mm would be ideal. 22mm may present troubles when fitting a socket in there.
