56 on Explorer chassis
Old Apr 9, 2017 | 03:29 PM
thomc's Avatar
thomc
No pics, but I saw a 56 on a complete all-wheel-drive Explorer chassis and running gear yesterday. The truck and owner reside in Ohio. It looked very interesting. I might consider an Explorer rear-wheel-drive swap. Anybody else done it? Anybody know the truck I'm talking about? It has a F250 but the builder shortened the bed to standard F100 length.
Old Apr 9, 2017 | 03:34 PM
dcavan001's Avatar
dcavan001
We have done the explorer 2wd rear-axle swap over this winter, from a '93. Lots of things to consider such as spring perches, narrower axle than the original, wheel swap, and other things I have forgotten. But the chance to get better gearing and a new set of brake components hopefully will make it worth it. We should know in the next few weeks.
Old Apr 9, 2017 | 04:27 PM
tip49's Avatar
tip49
frame height
Do the Explorer frames kick up at the rear , to eliminate about half the box depth ?
Tom
Old Apr 9, 2017 | 06:29 PM
Gicknordon's Avatar
Gicknordon
There was a guy on here a couple years ago that did that exact swap. I wonder if it was actually that guy that you saw? Can't remember where he was or what his screen name was.
Old Apr 9, 2017 | 07:14 PM
dcavan001's Avatar
dcavan001
I don't know if this is the member you mentioned, but here is one thread I found by searching the forum
https://www.ford-trucks.com/forums/1...4-55-56-a.html
Old Apr 9, 2017 | 10:55 PM
BTclassics's Avatar
BTclassics
Hopefully it looks better than this one on a Explorer chassis!
Recently I saw a picture of an Explorer with F100 sheet metal (poorly) grafted on the front. I don't recall where I saw it - it may have been on this forum somewhere.
I have a 1954 F100 on a 1994 Ranger chassis. The builder did a pretty nice job with the fabrication. I've been trying to finish it up and straighten out some issues.
Old Apr 10, 2017 | 01:23 PM
thomc's Avatar
thomc
Here's the one I saw. Looks great doesn't it?
Old Apr 10, 2017 | 01:25 PM
Ct70's Avatar
Ct70
Looks just perfect !
Old Apr 11, 2017 | 05:20 AM
petemcl's Avatar
petemcl
With all the aftermarket kits available for everything from IFS suspension, brakes, engine and trans adapters, complete wiring, steering column, etc. I'm not sure what you gain. With the frame swap in the end you have a classic truck on an old Explorer chassis. With aftermarket parts installed on your '56 you can do what you want but everything is new. Swapping the chassis seems like a lot of work for a negative gain.
As for the AWD there is more to making a good AWD vehicle than just a powered front axle and mediocre t-case. I'll leave it at that.
Old Apr 11, 2017 | 07:23 PM
BTclassics's Avatar
BTclassics
Are there better parts, sure. But one of the major overlooked factors is cost.
You could purchase an entire running explorer for the cost of some of these IFS kits. All depends on your goal and budget. I would rather have a Ford lightning swap, but that's not in the budget right now!
nairod
Sep 2, 2016 05:06 PM
hutchamatic
Feb 19, 2008 11:15 PM
wakesk8
Engine Swaps
Jul 29, 2004 11:56 PM
