New computer now engine surges :(
Old Apr 9, 2017 | 03:29 PM
NICKSAN's Avatar
NICKSAN
1994 E-150 5.8/351 E4OD
History: I had a bad computer, Installed a reman one and that cured the hard shifting
issue I had, but now I am having a surge problem. When stopped at idle it will surge
forward like its being given gas, It has did it one or two times every day in the week
since I have installed the reman computer. Today I drove about 10 miles and it did it
once but this time it was really bad and scared the crap out of me.
Yesterday I hooked back up a vacuum hose (related to the OBD1 code 311 I am getting) I found disconnect and installed a new PVC valve and grommet, thought that would fix the issue.
A few years ago I replaced:
Ignition coil
distributor cap and rotor
Idle air control valve (it was very clean when I removed it)
Ignition control module
Plugs and wires are only about 4 years old
Cleaned the throttle body, I really didnt need to because it looked super clean already
New radiator, thermostat and hoses, plus bypass hose.
I am getting a code 311, Thermactor system fault. This code was before and after I installed the reman computer, but before I did not have this surging problem.
I am also getting a error code 628, excessive clutch slippage. I found a link that says that might cause A surge issue. Does that sound right?
I am wondering?
Should I disconnect the battery so the computer can re-learn?
Should I keep looking for vacuum leaks?
Should I reinstall the old computer?
This is very hard to diagnose because it is very intermittent.
Thanks for any help.
e1p1
Mar 9, 2008 01:37 PM
Tom Norman
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
16
Apr 7, 2004 09:46 PM
radarsf150
May 31, 2003 11:22 AM
horsepower
Jan 22, 2002 11:59 AM
jimp
Computer Chips & Tuners
Dec 29, 2000 06:03 PM
