p0500 vss
Old Apr 9, 2017 | 11:17 AM
wedge542's Avatar
wedge542
p0500 vss
late build 03 f350 auto,i got a p0500 code and noticed sometimes after 2rd-3rd gear engages theres a shudder or fast vibration for few secs unless i let off,it didnt start this till i took batts out, where is the location of the vss at,im seeing some say at each wheel,ontop rear diff,ontop back of trans so not real sure?
Old Apr 9, 2017 | 01:20 PM
TooManyToys.'s Avatar
TooManyToys.
The sensor at the rear differential feeds the abs, then it goes to all other electronics; pcm, gauge panel, cruise, OH display. I believe the trans takes its clue from the pcm. Are any other components getting the speed signal? Gauge? ABS light on?
Old Apr 9, 2017 | 02:32 PM
wedge542's Avatar
wedge542
The abs lite was on but went off and not returned,
Old Apr 9, 2017 | 02:36 PM
wedge542's Avatar
wedge542
When i use the tow haul noshuddering at all, for a day my tow haul would blink,discon batts,drove awhile and feel shudder insome gears,cked with forscan p0500,its a 4wd if that matters,i cked all fuses,all good.
Old Apr 9, 2017 | 07:45 PM
TooManyToys.
If the ABS light was on too, then there may not be a clear signal pattern out of the Speed sensor in the rear diff. You could try pulling it and see if it's covered with metal wear particles. If so, wipe them off and see if it improves. In the future you may still need to replace the sensor, but check if it's wires in the area are damaged.
I'm not sure how sensitive the trans software is, if a varying signal will interfere with the shifting. But for trans issues Mark K is the best person who would know.
Old Apr 9, 2017 | 07:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The VSS is on top of the rear differential. That is the sensor (or the wiring attached to the sensor) that can set a P0500.
Old Apr 9, 2017 | 08:50 PM
wedge542's Avatar
wedge542
Thanks,ill ck things out there.
Old Apr 10, 2017 | 09:35 AM
wedge542's Avatar
wedge542
Anyone know what this should ohm out at,i seen one site say anything below 1900 is bad?
Ford'05HG
1983 - 2012 Ranger & B-Series
Jun 1, 2016 07:06 AM
Crazy2
Jan 24, 2012 12:57 PM
Franko72
Aug 4, 2010 08:07 PM
orrenk
Feb 22, 2005 11:38 PM
