Help fuel issues!!!!!!
Old Sep 1, 2003 | 05:08 PM
txlnghrn's Avatar
txlnghrn
I have a 93 F-150 xcab w/ a 5.0 in it. When idling and driving at low speeds it acts like it is not getting any gas and dies. When I get on the road and get to driving 30 and up, it runs fine.
HELP!!!!!!!!!
What should I start checking?
Old Sep 1, 2003 | 05:41 PM
PCWest13's Avatar
PCWest13
My '94 did the exact same thing. I replaced the fule filter and did a tune up on the engine (rotor bug, distributor cap, spark plugs, wires). My main problem was that my truck has over 230 thousand miles on it and had never been given a tune up, and the piece on top of the spark plug was non existant. It was a miracle it still ran. But I would start with the things I listed, it made mine run like new. I thought it would cut out everytime I tried to give it gas until I got a new engine, but now it runs like a champ..
Old Sep 1, 2003 | 09:42 PM
LxMan1's Avatar
LxMan1
If the tune up doesn't help, I would look into the EGR valve for being carboned up and possibly the tps sensor being worn out.
Jimmy
Old Sep 4, 2003 | 09:31 AM
txlnghrn's Avatar
txlnghrn
Question Help fuel issues!!!!!!
I stopped by Autozone and the guy hooked up a code reader and this is what came up.
Code: 172 = HEGO sensor low voltage
Code: 327 = Egr valve low voltage
Code: 122 = TPS sensor low voltage
Is the a code book on here so I can verify what the Autozone guy told me?
Also, What would cause low voltage? Are the sensor's going out? Or is it the altenator?
Old Sep 5, 2003 | 01:50 AM
Ford_Six's Avatar
Ford_Six
Probably a bad ground or bad connection, with that many sensors showing low voltage.
Nichole Johnson
Crossovers
Oct 4, 2013 03:50 PM
78MICK150
Jun 7, 2004 11:31 PM
mnmt_12
1978 - 1996 Big Bronco
Jan 4, 2002 02:53 PM
Fordman
Aug 24, 1999 03:37 PM
