1978 - 1996 Big Bronco
gas gauge
Old Jan 4, 2002 | 11:04 AM
mnmt_12's Avatar
mnmt_12
gas gauge
I need to get my gas gauge fixed on my 1979 Ford Bronco. Is there a simple solution?
My teenage son is driving it and it makes me worry when he's out.
Please help.
Concerned MOM in OHIO
Old Jan 4, 2002 | 01:55 PM
honney's Avatar
honney
gas gauge
It could be the gauge but most likely the sending unit in the gas tank needs to be replaced, this will involve dropping the gas tank.
Old Jan 4, 2002 | 01:57 PM
AlM's Avatar
AlM
gas gauge
[updated:LAST EDITED ON 04-Jan-02 AT 03:11 PM (EST)]mom,
look here for info:
http://www.off-road.com/ford/bigbroncos/bbfaq.html#12
"...Why does my Fuel guage behave erratically?
This is a common problem with older Broncos. It can be caused by several things.
If the gauge reads normally for some of its range, but reads full or bounces between full and the real value, the most likely cause is a worn level sender. The fuel level sender is a variable resistor located in the gas tank. A wiper attached to the float rides across the resistor, causing a change in the resistance seen by the dashboard gauge. A high resistance (by Al,, I think it's 100 ohms) reads as "Full" on Ford gas guages by Al, and open is empty). Over time, the wiper may wear through the resistor, causing dead spots which read as full. The only fix for this problem is to replace the sender. On later model vehicles with in-tank fuel pumps, this can be an expensive proposition. Ford only sells the fuel level sender as part of the fuel pump assembly, which can run well over $150.
If the gauge behavior doesn't follow any specific pattern, then it is probably related to some other electrical problem. You may want to inspect the wires from the fuel level sender to the guage to see if they are possibly damaged. important...>>>>> If other gauges are also erratic, there is a good chance that the dashboard voltage regulator is bad."
and...Our 78 bronco had a broken piece of pllastic behind the gauge panel that cause an open ckt.
Old Jan 4, 2002 | 02:53 PM
dwatts's Avatar
dwatts
gas gauge
Planejet42
Apr 12, 2016 06:49 PM
aaronsbicyclerepair
Jun 1, 2015 04:50 AM
zehcnasca
Nov 10, 2011 10:33 PM
inkpusher2004
Aug 1, 2005 05:29 AM
frachubb
Bronco II
Oct 28, 2003 08:44 AM
